Motor shield + UNO. Stepper motor +photomicrosensor script
Postby oinkoink12 » Mon Mar 12, 2012 11:03 am
I want to create a script for a steppermotor that finds it 0point when the Photomicrosensor is activated.
I tried combinding 2 existing working scripts but i failed horribly.
Can any of you point me in the right direction?
// Adafruit Motor shield library
// copyright Adafruit Industries LLC, 2009
// this code is public domain, enjoy!
#include <AFMotor.h>
#define STEPS 2000
// Connect a stepper motor with variable steps per revolution
// to motor port #2 (M3 and M4)
AF_Stepper motor(STEPS, 2);
int previous = 0;
  Serial.begin(9600);           // set up Serial library at 9600 bps
  Serial.println("Stepper test!");
  motor.setSpeed(30);  // 30 rpm
void loop()
  Serial.println("Single coil steps");
  motor.step(100, FORWARD, SINGLE);
  motor.step(100, BACKWARD, SINGLE);
  // get the sensor value
  int val = analogRead(0);
  // move a number of steps equal to the change in the
  // sensor reading
  AF_Stepper.step(val - previous);
  // remember the previous value of the sensor
  previous = val;
oinkoink12
Re: Motor shield + UNO. Stepper motor +photomicrosensor script
Postby adafruit_support_bill » Mon Mar 12, 2012 11:35 am
These two lines go one step forward and one step back. What are you trying to accomplish here?
What kind of sensor is this? What is the range of outputs?
This is not valid syntax. You need to use:
      motor.step(val - previous);
Postby oinkoink12 » Tue Mar 13, 2012 2:33 am
I tried to accomplish 100 steps forward, 100 steps backwards, and that worked in the previous script.
The kind of sensor I need to use is http://www.omron.com/ecb/products/pdf/en-ee_sv3_series.pdf
When I change the script to what you suggested i get
StepperTestX.cpp: In function 'void loop()':
StepperTestX:29: error: no matching function for call to 'AF_Stepper::step(int)'
C:\Users\simteq\Desktop\Tims Rommelhoek\arduino\arduino-1.0\libraries\Simteq/AFMotor.h:90: note: candidates are: void AF_Stepper::step(uint16_t, uint8_t, uint8_t)
oinkoink12
Postby oinkoink12 » Tue Mar 13, 2012 4:25 am
Ok, I started over again!
This works:
// Connect a stepper motor with 1000 steps per revolution (0,36 degree)
AF_Stepper motor(1000, 2);
  motor.setSpeed(20);  // 20 rpm
  motor.step(1000, FORWARD, SINGLE);
  motor.step(1000, BACKWARD, SINGLE);
This makes my motor go 1 complete circle forwards and 1 complete circle backwards, over and over again.
What I want is my photomicrosensor (which I connected to Analog0 on the Shield) that it recognizes my 0 point on the sensor and that I can reset my forward/backward based on the position of the 0.
Example:
0 point on sensor is on step 100 so it can go back 100 steps and 900 steps forwards.
I think I need to work with this?
int sensorPin = A0;    // select the input pin for the photomicrosensor
int sensorValue = 0;  // variable to store the value coming from the sensor
  // read the value from the sensor:
  sensorValue = analogRead(sensorPin);
I will now try this:
  Serial.println(sensorValue, DEC);
oinkoink12
Postby adafruit_support_bill » Tue Mar 13, 2012 4:55 am
Your sensor is a digital sensor. It senses when the gap is interrupted. I assume that you have some sort of slotted wheel or "flag" attached to the stepper shaft? To detect when the gap is interrupted, you should be using "digitalRead" not "analogRead" to read it.
Typical useage of these with a stepper involves single-stepping toward where "home" should be and stopping when the sensor detects the home flag. For faster performance, you can do a multi-step move to cover most of the distance, the switch to single-steps when you are close to home.
Postby oinkoink12 » Tue Mar 13, 2012 5:17 am
adafruit_support wrote:Your sensor is a digital sensor. It senses when the gap is interrupted. I assume that you have some sort of slotted wheel or "flag" attached to the stepper shaft? To detect when the gap is interrupted, you should be using "digitalRead" not "analogRead" to read it.
When I had it on analog it gave me "1023" as result (thats the steps for a full circle) when i switched to digital it gave me "1"
oinkoink12
Postby adafruit_support_bill » Tue Mar 13, 2012 5:49 am
No. That sensor does not count steps. 1023 is the full-scale analog reading of 5v - which is equivalent to logic-level '1' or TRUE.
Postby oinkoink12 » Tue Mar 13, 2012 6:34 am
Your right :) (you prolly allready knew that)
Ok, so i change my analogRead to digitalRead. It gives an output of "1" when it arrives there.
I tried this but it just stops after the 2000 steps. How can I get it to stop at the sensorpoint?
AF_Stepper motor(1023, 2);
  motor.step(2000, FORWARD, SINGLE);
  //motor.step(1023, BACKWARD, SINGLE);
  sensorValue = digitalRead(sensorPin);
      if (sensorValue > 0)
  motor.setSpeed(0);
oinkoink12
Postby adafruit_support_bill » Tue Mar 13, 2012 6:46 am
Assuming that your sensor reads '1' when the motor is in the 'home' position:
     int homeFlag = digitalRead(sensorPin)
     while (!homeFlag)  // step until home
       motor.step(1, BACKWARD, SINGLE);
Postby oinkoink12 » Tue Mar 13, 2012 7:05 am
adafruit_support wrote:Assuming that your sensor reads '1' when the motor is in the 'home' position:
It seems my sensor works the other way around, its a constant 1 and it read '0" when its in the home position.
So that solution doesnt work for me :(
oinkoink12
Postby adafruit_support_bill » Tue Mar 13, 2012 7:35 am
If the sensor logic is inverted, you need to invert the logic in the while.
while (homeFlag)  // step until home
Postby oinkoink12 » Tue Mar 13, 2012 7:45 am
adafruit_support wrote:If the sensor logic is inverted, you need to invert the logic in the while.
From learning all these new things my logic is allready inverted today :) :) Thanks for your patient help
My code now is this:
  motor.step(200, FORWARD, SINGLE);
     int homeFlag = digitalRead(sensorPin);
      if (sensorValue < 1)
  motor.setSpeed(0);
It goes 200 steps forward, then gives a 1 as output and then goes backwards forever. It seems to not check the sensor every step. What could that be?
oinkoink12
Postby adafruit_support_bill » Tue Mar 13, 2012 7:52 am
My apologies. :oops: Not enough coffee yet this morning.
You need to have the sensor read as part of the while loop. Otherwise it will never change!
     while (digitalRead(sensorPin))  // step until home
Postby oinkoink12 » Tue Mar 13, 2012 8:05 am
adafruit_support wrote:My apologies. :oops: Not enough coffee yet this morning.
This works!
Tomorrow I will proceed on the next steps!
oinkoink12
Return to General Project help
Users browsing this forum: Google [Bot] and 10 guests
New Products [102]
LEDs[109]
Cables[60]
