Issue with micro SD breakout
Postby wwalkin » Mon Apr 23, 2012 10:24 pm
I have a micro SD breakout and I am able to write to the card, that is create files and write to them. The issue I have is that the data is being written more than once. I am using the code provided on the micro SD tutorial. What could the problem be? The serial monitor shows that the code ran only once but still data is being written two or three time rather than once.
#include <SD.h>
File myFile;
void setup()
  Serial.begin(9600);
  Serial.print("Initializing SD card...");
  // On the Ethernet Shield, CS is pin 4. It's set as an output by default.
  // Note that even if it's not used as the CS pin, the hardware SS pin
  // (10 on most Arduino boards, 53 on the Mega) must be left as an output
  // or the SD library functions will not work.
   pinMode(53, OUTPUT);
  if (!SD.begin(53)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  myFile = SD.open("test.txt", FILE_WRITE);
  // if the file opened okay, write to it:
  if (myFile) {
    Serial.print("Writing to test.txt...");
    myFile.println("testing 1, 2, 3.");
   // close the file:
    myFile.close();
    Serial.println("done.");
  } else {
    // if the file didn't open, print an error:
    Serial.println("error opening test.txt");
void loop()
   // nothing happens after setup
wwalkin
Re: Issue with micro SD breakout
Postby franklin97355 » Mon Apr 23, 2012 11:37 pm
Do you erase the file between tests?
franklin97355
Postby adafruit_support_bill » Tue Apr 24, 2012 4:47 am
The code starts running automatically after each reset. It will start running as soon as you upload the sketch. And then when you open the serial monitor, it will assert DTR which will reset the board and the sketch will start running again.
Return to General Project help
Users browsing this forum: lawnbuddy and 7 guests
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
