I need help with getting my gps and bmp085 sensor working with arduino
Postby DatBoyEvV » Wed Apr 25, 2012 8:39 am
I have been working with this for a couple of days and i can not get this program working. It keeps saying i have and error compiling the program.
Here is the program:
#include <NewSoftSerial.h>
#include <Wire.h>
#include <SD.h>
#include <Adafruit_BMP085.h>
#include <avr/sleep.h>
#include "GPSconfig.h"
//#include <SoftwareSerial.h>
#define SLEEPDELAY 0
#define TURNOFFGPS 0
#define LOG_RMC_FIXONLY 0
#define GPSRATE 4800
#define powerPin 4
#define led1Pin 5
#define led2Pin 6
#define chipSelect 10
#define BUFFSIZE 90
NewSoftSerial gpsSerial(2, 3);
char buffer[BUFFSIZE];
uint8_t bufferidx = 0;
uint8_t fix = 0;
uint8_t i,j,k;
char *parseptr;
float Temperature;
int32_t Pressure;
float lat,lon,temp;
char date[7];
char utc_time[10];
char alt[10];
File logfile;
Adafruit_BMP085 bmp;
uint8_t parseHex(char c) {
  if (c < '0')
   return 0;
  if (c <= '9')
   return c - '0';
  if (c < 'A')
   return 0;
  if (c <= 'F')
   return (c - 'A')+10;
void error(uint8_t errno) {
  while(1) {
   for (i=0; i<errno; i++) {
    digitalWrite(led1Pin, HIGH);
    digitalWrite(led2Pin, HIGH);
    delay(100);
    digitalWrite(led1Pin, LOW);
    digitalWrite(led2Pin, LOW);
    delay(100);
   for (; i<10; i++) {
    delay(200);
void readline(void) {
  char c;
  bufferidx = 0;
  gpsSerial.read();
  while (1) {
   c=gpsSerial.read();
   if (c == -1)
    continue;
   if (c == '\n')
    continue;
   if ((bufferidx == BUFFSIZE-1) || (c == '\r')) {
    buffer[bufferidx] = 0;
    return;
   buffer[bufferidx++]= c;
  WDTCSR |= (1 << WDCE) | (1 << WDE);
  WDTCSR = 0;
  Serial.println("\r\nGPS and BMP085 logger");
  pinMode(led1Pin, OUTPUT);
  pinMode(led2Pin, OUTPUT);
  pinMode(powerPin, OUTPUT);
  digitalWrite(powerPin, LOW);
  pinMode(10, OUTPUT);
  if (!SD.begin(chipSelect)) {
   Serial.println("Card init. failed!");
   error(1);
  strcpy(buffer, "AQDLS.TXT");
  for (i = 0; i < 100; i++) {
   buffer[6] = '0' + i/10;
   buffer[7] = '0' + i%10;
   if (! SD.exists(buffer)) {
    break;
  logfile = SD.open(buffer, FILE_WRITE);
  if( ! logfile ) {
   Serial.print("Couldnt create ");
   Serial.println(buffer);
   error(3);
  Serial.print("Writing to ");
  logfile.println("# A GPS track data file");
  logfile.println("# UTC time  lat  lon  gps_alt  pressure temperature");
  logfile.println("# hhmmss.sss deg  deg  m     hPa    C");
  logfile.println("#");
  gpsSerial.begin(GPSRATE);
  Serial.println("Ready!");
  gpsSerial.print(SERIAL_SET);
  delay(250);
  gpsSerial.print(GGA_ON);
  delay(250);
  gpsSerial.print(RMC_OFF);
  delay(250);
  gpsSerial.print(WAAS_ON);
  bmp.begin();
  char c;
  uint8_t sum;
  char *p;
  readline();
  Serial.print("raw line: ");
  sum = parseHex(buffer[bufferidx-2]) * 16;
  sum += parseHex(buffer[bufferidx-1]);
  Serial.print("Checksum:");
  Serial.println(sum);
  for (i=1; i < (bufferidx-3); i++) {
   sum ^= buffer[i];
  if (sum != 0) {
   Serial.print('~');
   bufferidx = 0;
   return;
  p = buffer;
  p = strchr(p, ',')+1;
  for (k=0;k<9;k++)
   utc_time[k]=p[k];
  Serial.print(" UTC time:");
  Serial.println(utc_time);
  lat = (p[0]-'0')*10.0 + (p[1]-'0') + ((p[2]-'0')*10.0 + (p[3]-'0') + (p[5]-'0')/10.0 + (p[6]-'0')/100.0 + (p[7]-'0')/1000.0 + (p[8]-'0')/10000.0)/60.0;
  if (p[0]=='S')
   lat *= -1.0;
  Serial.print(" latitude:");
  Serial.println(lat,7);
  lon = (p[0]-'0')*100.0 + (p[1]-'0')*10.0 + (p[2]-'0') + ((p[3]-'0')*10.0 + (p[4]-'0') + (p[6]-'0')/10.0 + (p[7]-'0')/100.0 + (p[8]-'0')/1000.0 + (p[9]-'0')/10000.0)/60.0;
  if (p[0]=='W')
   lon *= -1.0;
  Serial.print(" longitude:");
  Serial.println(lon,7);
  if (p[0]=='0') {
   fix = 0;
  else {
   fix = 1;
  j=0;
  while (p[j] != ',') {
   alt[j] = p[j];
   j++;
  Serial.print(" alt:");
  Serial.println(alt);
  bufferidx = 0;
  logfile.print(date);
  logfile.print(" ");
  logfile.print(utc_time);
  logfile.print(" ");
  logfile.print(lat,7);
  logfile.print(" ");
  logfile.print(lon,7);
  logfile.print(" ");
  logfile.print(alt);
  logfile.print(" ");
  Temperature = bmp.readTemperature();
  Serial.print("Temperature = ");
  Serial.print(Temperature);
  Serial.println(" C");
  Pressure = bmp.readPressure();
  Serial.print("Pressure = ");
  Serial.print(Pressure);
  Serial.println(" Pa");
  logfile.print(" ");
  logfile.print(Pressure);
  logfile.print(" ");
  logfile.println(Temperature);
  logfile.flush();
  if (TURNOFFGPS) {
   digitalWrite(powerPin, HIGH);
  delay(SLEEPDELAY * 1000);
  return;
DatBoyEvV
Re: I need help with getting my gps and bmp085 sensor working with arduino
Postby franklin97355 » Wed Apr 25, 2012 10:17 am
With such long code it would make it more readable if you were to enclose it within "CODE" tags. You can go back and edit your existing post.
franklin97355
Postby adafruit_support_bill » Wed Apr 25, 2012 11:28 am
It would help if you posted the text of the error too.
Postby DatBoyEvV » Wed Apr 25, 2012 11:44 am
Sorry about that
here is the error:
Error compiling
In file included from sketch_apr24a.cpp:1:
C:\Users\EVV\Desktop\arduino-1.0\libraries\NewSoftSerial/NewSoftSerial.h:71: error: conflicting return type specified for 'virtual void NewSoftSerial::write(uint8_t)'
C:\Users\EVV\Desktop\arduino-1.0\hardware\arduino\cores\arduino/Print.h:48: error:   overriding 'virtual size_t Print::write(uint8_t)'
DatBoyEvV
Postby adafruit_support_bill » Wed Apr 25, 2012 12:17 pm
Looks like you are using the Arduino 1.0 IDE. Starting with 1.0, the functionality of NewSoftSerial has been integrated as "SoftwareSerial". You should replace your "#include <NewSoftSerial.h>" with "#include <SoftwareSerial.h>". You should also remove the NewSoftSerial folder from your libraries folder to avoid conflicts.
Another problem you are likely to encounter has to do with: "#include <Adafruit_BMP085.h> ". Unless you renamed it when you installed it, the name of the file is just "BMP085.h ".
Postby DatBoyEvV » Wed Apr 25, 2012 1:11 pm
I changed the " #include <NewSoftSerial.h>" to " #include <SoftwareSerial.h>" and took the NewSoftserial library out and now im getting this error
'gpsSerial' was not declared in this scope
sketch_apr24a.cpp: In function 'void readline()':
sketch_apr24a:69: error: 'gpsSerial' was not declared in this scope
sketch_apr24a.cpp: In function 'void setup()':
sketch_apr24a:121: error: 'gpsSerial' was not declared in this scope
DatBoyEvV
Postby DatBoyEvV » Wed Apr 25, 2012 1:44 pm
yes i did , here is the code
#include <Wire.h>
#include <SD.h>
#define powerPin 4
#define led1Pin 5
#define led2Pin 6
#define BUFFSIZE 90
uint8_t fix = 0;
uint8_t i,j,k;
char *parseptr;
float Temperature;
int32_t Pressure;
float lat,lon,temp;
char date[7];
char utc_time[10];
char alt[10];
File logfile;
  if (c < '0')
   return 0;
  if (c <= '9')
   return c - '0';
  if (c < 'A')
   return 0;
  if (c <= 'F')
  while(1) {
    delay(100);
    delay(100);
   for (; i<10; i++) {
    delay(200);
  char c;
  bufferidx = 0;
  gpsSerial.read();
  while (1) {
   c=gpsSerial.read();
   if (c == -1)
    continue;
   if (c == '\n')
    continue;
    return;
  WDTCSR = 0;
   error(1);
    break;
  if( ! logfile ) {
   error(3);
  delay(250);
  delay(250);
  delay(250);
  bmp.begin();
  char c;
  uint8_t sum;
  char *p;
  readline();
   sum ^= buffer[i];
  if (sum != 0) {
   Serial.print('~');
   bufferidx = 0;
   return;
  p = buffer;
  for (k=0;k<9;k++)
   utc_time[k]=p[k];
  if (p[0]=='S')
   lat *= -1.0;
  if (p[0]=='W')
   lon *= -1.0;
  if (p[0]=='0') {
   fix = 0;
  else {
   fix = 1;
  j=0;
   alt[j] = p[j];
   j++;
  bufferidx = 0;
  logfile.print(" ");
  logfile.print(" ");
  logfile.print(" ");
  logfile.print(" ");
  logfile.print(alt);
  logfile.print(" ");
  logfile.print(" ");
  logfile.print(" ");
  logfile.flush();
  if (TURNOFFGPS) {
  return;
DatBoyEvV
Postby adafruit_support_bill » Wed Apr 25, 2012 1:51 pm
No, it looks like you deleted the declaration entirely. In your previous posted code you had it declared as:
In the last post there is no declaration at all. You need to add it back in as:
    SoftwareSerial gpsSerial(2, 3);
Return to General Project help
Users browsing this forum: mibignistinly and 10 guests
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
