Schematic of PN532 NFC/RFID Controller Shield for Arduino
Postby rimbox » Wed Apr 25, 2012 11:55 am
where can I find the links of pins 0-13 Digital and 0-5 Analog for "PN532 NFC/RFID Controller Shield for Arduino"? The schematic pdf is same of "PN532 NFC/RFID controller breakout board", so I can't understand it.
Can I access to RX and TX Usart in Arduino version?
I little note, the distributors in Europe for these products are very bad, only one distributor has it and very high price.
I would like to support Adafruit for the great work but it's not easy. In reply to: https://github.com/adafruit/Adafruit_NFCShield_I2C
I asked to watterott (german distributor) but don't want insert it.
Thank you for your help
rimbox
Re: Schematic of PN532 NFC/RFID Controller Shield for Arduino
Postby adafruit » Wed Apr 25, 2012 1:58 pm
Hi the shield uses digital 2 and analog 4 and 5 only. No other pins are connected, we'll have the files up shortly!
Postby rimbox » Sat Apr 28, 2012 3:33 pm
only 3 pins should be MOSI, MISO and SCK. No IRQ?
I would like to see SCH file.
I see for product "PN532 NFC/RFID controller breakout board" there is watterott in list of distributors. Please remove it, is not true. Try to search in their shop PN532, this product doesn't exist. One month ago tell me "I insert it in next 2 days". I wrote many times without response from them.
rimbox
Postby adafruit » Mon Apr 30, 2012 3:11 pm
IRQ is used as well, digital pin #2 - we'll try to get the files up soon, we dont have an ETA as to when we will put them up - we have a lot of board files to go thru!
Postby rimbox » Fri May 18, 2012 3:45 pm
After more than 2 weeks, nothing has changed.
In the list of distributors for "PN532 NFC/RFID controller breakout board" there is WatteRott and WatteRott not has this product in the shop.
Schematic PDF for "PN532 NFC/RFID Controller Shield for Arduino" is always wrong.
rimbox
Postby adafruit » Fri May 18, 2012 4:54 pm
rimbox wrote:After more than 2 weeks, nothing has changed.
thank you posting, watterott has stocked these, but will check to see when their next order arrives. we'll also double check the PDF/link for the schematic. we're at maker faire at the moment, but we'll be returning after the weekend and make sure we correct any bad links.
you can also contact us directly next week if needed: support@adafruit.com
thanks,
adafruit support, phil
Users browsing this forum: No registered users and 10 guests
New Products [103]
LEDs[109]
Cables[61]
