String and Array Confusion
Postby bafil » Wed Apr 25, 2012 4:16 pm
Hello All
I am working on a POV clock that is giving me a hard time in the coding department. I am at a point where I have been able to get data from a RTC breakout board and store the values. I also have been able to assign those values to a predefined character set for the POV. I am able to display the Hours values, the minutes values, and the seconds values. HOWEVER, I can only display them individually and not all at once. I think I am not creating either a string or an array correctly.
Here is a part of my sketch that deals with this issue:
//Declaring variables.
  int Hrs = now.hour();
  int Mins = now.minute();
  int Sec = now.second();
  int Time =(Hrs, Min, Sec);
  //This is just for debugging. Just to see what is being sent to the LED's
  Serial.println(Time);
  delay(1000);
Ok, at this point when I put all three values in "int Time" all I get is my seconds value printing out on the serial monitor and on my POV clock.
How can I get it to show all individual values. Keep in mind, I am only using the Serial.print command here JUST to see whats being sent to my POV display.
Phillip B.
bafil
Re: String and Array Confusion
Postby pburgess » Wed Apr 25, 2012 4:55 pm
Greetings from one Phillip B. to another. :D
Problem is with these lines:
The first line doesn't concatenate the values, nor are they being passed to a function. The syntax is still valid C though -- the comma operator normally lets you handle multiple assignments on one line (most frequently seen in the setup of 'for' loops)...but in this case, reduces to the equivalent of:
  int Time = Sec;
To get these into a string (which is probably what you want), there are a couple of approaches...easiest is probably sprintf(), a la:
  char Time[9];
  sprintf(Time, "%02:%02:%02", Hrs, Min, Sec);
The POV display code will then need to walk through the string, converting each ASCII character to your corresponding bitmap.
pburgess
Postby bafil » Wed Apr 25, 2012 5:30 pm
Hey Phillip B.
Thanks for the help but I still could not get what I needed.
I posted the entire code that I am using, so maybe it will be easier to understand. I had help with the code so there are still parts of it I am a bit confused about.
bafil
Postby pburgess » Wed Apr 25, 2012 5:46 pm
You have both a local and a global variable named 'Time'. Inside the loop() function, don't declare the variable Time at all (so disregard that line in the code I previously posted)...remove the line, leave the global declaration at top, then sprintf() into the string as I showed. Should work at that point.
pburgess
Postby bafil » Mon Apr 30, 2012 9:30 am
Thanks for your help Phillip B.
I went through my code some more and did the changes you said and I finally got it to work.
Thanks again for your help
bafil
Return to General Project help
Users browsing this forum: frontside180, Google [Bot] and 5 guests
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
