Adafruit Ultimate GPS Breakout - 66 channel w/10 Hz updates - MTK3339 chipset
Postby dmh » Mon Apr 30, 2012 1:24 pm
I was trying to figure out how to hook up an lcd to show the location by the MTK3339. I'm not sure about how to wire up both to it.
Any hints or clues are appreciated.
Mike
dmh
Re: Adafruit Ultimate GPS Breakout - 66 channel w/10 Hz updates - MTK3339 chipset
Postby franklin97355 » Mon Apr 30, 2012 11:08 pm
You will probably need to add a microcontroller to the mix to support the translation between the two devices.
franklin97355
Postby BudgetEngineer » Wed May 02, 2012 11:59 am
Hi, I have been toying with this idea for awhile. I have a Sparkfun OpenLog data logger that is by default set up to log any data it recieves on the serial line at 9600 baud. My thinking is that if you coupled this directly to the 9600 baud Ultimate GPS then it would automatically log the GPS data. This way you wouldn't need a micro to set up the internal logging of the Ultimate GPS and maintain 10hz updates. I'm not sure how well this would work with a serial-enabled LCD like the https://www.adafruit.com/products/784 that defaults to 9600 baud as well. This might work in a pinch, but the NMEA GGA strings coming out of the GPS are likely to be longer than 32 characters. Also at a 10hz data update, the character strings are likely to be unreadable. This should be trivial to do with an Arduino in the middle though.
BudgetEngineer
BudgetEngineer
Badges: Educational Mini UAVs Skill Badge awarded to BudgetEngineer by AdafruitHigh-altitude Balloon Skill Badge awarded to BudgetEngineer by Adafruit
Postby dmh » Fri May 04, 2012 1:24 pm
Hi
I am not sure I understand. How would you couple the GPS to Sparkfuns OpenLog data logger?
Mike
dmh
Postby rj44319 » Fri May 04, 2012 2:53 pm
GPS SF Data Logger
Tx ---------------->RX
GND--------------GND----------------------------V
5v----------------5v-----------------------------PSU
rj44319
Return to General Project help
Users browsing this forum: No registered users and 11 guests
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
