Shared Ground
britesc
Shared Ground
Post by britesc »
Can different DC Voltages share the same ground.
I have an Adafruit large breadboard with 4 terminals.
Can I mark them up as Ground, 3VDC, 5VDC & 9VDC.
Making the futherest righthand column Ground, the next 3VDC, then the nearest righthand 5VDC, and the last 9VDC?
Thanks and kind regards,
jB 8)
britesc
Re: Shared Ground
Post by britesc »
Oops Sorry,
Making the futherest lefthand column Ground, the next 3VDC, then the nearest righthand 5VDC, and the last 9VDC?
Re: Shared Ground
Yes. Generally, all power sources in your project should be referenced to the same ground. If you are using multiple supplies to get these different voltages, you should connect all the grounds together.
britesc
Re: Shared Ground
Post by britesc »
Thank you very much.
Kind regards,
jB 8)
