Item pieces counter for Industry
by pechial on Fri Aug 03, 2012 6:13 am
Hi folks! :D
I would like to ask to the forum if this project could be able to accomplish:
We have some machines in our company that makes pieces. Each piece runs in a track and falls in a container.
The manager wants to know how many pieces has been produced each period of time (f.e. each hour)
I'm looking for the items than cant do that tasks:
-Laser / sensor (like an intrusion circuit, each piece moving the track would open/close the circuit) and finally fall into a container.
-Network adapter, to get the impulse of the laser , each piece would generate that pulse
-Software capable to read from the network adapter
From this part to the management software would be a diferent step and now i'm focused in the scenario to catch that item's counter product) in a pc workstation.
What products should I need and would you kindly help me into how to read from the laser interface to a PC ? (like dll, usb driver, netword signal, ...)
Thank you!!!! :) :) :)
Carles
pechial
Re: Item pieces counter for Industry
by adafruit_support_bill on Fri Aug 03, 2012 6:39 am
There are a lot of different ways to sense objects. The best sensor to use will vary depending on the object (size, shape, color, material etc) as well as variables like the surrounding environment and how fast it is moving. In most cases, some experimentation is required to determine the best sensor for the job.
One approach a light beam. These can detect when the object breaks the beam.
http://www.adafruit.com/products/157
http://www.adafruit.com/products/161
Other solutions include proximity detectors and rangefinders. These can detect when an object passes within a certain distance:
http://www.adafruit.com/products/466
http://www.adafruit.com/products/172
http://www.adafruit.com/products/164
Cameras such as this one have motion-detection capability and can signal when something moves in the field of view:
http://www.adafruit.com/products/397
There are mechanical ways to detect objects as well:
http://www.adafruit.com/products/820
by lyndon on Sat Aug 04, 2012 11:57 am
If you are looking for something off the shelf, I build systems that do counting. Send me a PM (private message) if interested .
If you prefer to DIY, I can help you select components that would be suitable or help with ways to package the sensors adafruit suggested.
lyndon
by lyndon on Sat Aug 04, 2012 12:05 pm
@adafruit_support: can you send me a PM? There doesn't seem to be a way for me to send you one :-(
lyndon
by pechial on Mon Aug 06, 2012 7:39 am
lyndon wrote:@adafruit_support: can you send me a PM? There doesn't seem to be a way for me to send you one :-(
I've sent a message, did you receive it ?
pechial
by adafruit_support_bill on Mon Aug 06, 2012 8:51 am
@pechial - It looks like you reported the post instead of sending a PM. To send a PM to Lyndon, click on lyndon's name and look for the PM link under "Contact Lyndon".
by lyndon on Mon Aug 06, 2012 11:37 am
Yup, I got your message and responded. It should be in your Inbox now.
To sum up: my counters use Bluetooth & RS232, not Ethernet.
Using adafruit parts, it looks like an Arduino (http://www.adafruit.com/products/50), an Ethernet shield (http://www.adafruit.com/products/201) and an IR sensor such as (http://www.adafruit.com/products/164) will get you started.
lyndon
