Sharp 2Y0A21 F 23 Help
I'm working on my first project outside of step by step projects I've done. I was wondering if someone could answer my question about the Sharp 2Y0A21 F 23. Can I use it as both a proximity sensor AND act as a IR sensor that receives IR codes? If so, how? I'll be using this with a Teensy 2.0.
Re: Sharp 2Y0A21 F 23 Help
I'm not sure if this is allowed, but bump. This is going to be a key piece of my halloween costume. It will be epic.
- adafruit_support_bill
The sharp IR rangefinders do not give you a raw IR sensor output. The only output is the rangefinder output.Can I use it as both a proximity sensor AND act as a IR sensor that receives IR codes?
