Hey Everyone,
I want to build a small display for an arduino project. Instead of sending out a voltage reading on an LCD screen or an LED setup, I want it to display as a meter movement. Like a galvanometer. I understand how PMMC's work, but for my project I don't need a huge meter like the ones you typically buy from radioshack. All I need is a tiny pin to move through a range of around 270 degrees with the diameter of 1.5 cm. Is there an easier way of building a meter movement without having to use a permenant magnet, hairspring coils, etc.? Something that would be relatively cheap and inexpensive?
Thank you so much!
DIY Small Meter Movement?
- lyndon
Re: DIY Small Meter Movement?
You can probably use a pager/cellphone vibrator motor. Remove the offset weight and it's just a motor. Now add a spring to the shaft and you have a motor that will rotate according to how much current you feed it.
Mechanically tricky if you don't have the right tools, but it will work and is about the right size.
Or, if you have an extra $35 burning a hole in your pocket, use this tiny stepper motor: http://www.digikey.com/product-detail/e ... ND/2417057
- easternstargeek
If you can live with 180 degrees, use an inexpensive hobby servo. Since you are driving it with an Arduino, you have everything you need.
I have done this to make a large dial thermometer with excellent results.
It won't be as speedy as a d'Arsonval movement, but it should do the job for less than US$6.00:
http://www.adafruit.com/products/169
Thanks for the responses! I don't think they will work for my project though. Sorry I wasn't specific before, but I am building a midi controller, but I want all the displays for each knob to change when I adjust the value each knob controls on the computer. So for example, if I had my midi controller mapped to a software synthesizer, and then I changed presets for that synthesizer on the computer, my custom midi controller would know and it would change its display values accordingly.
Therefore, the option of using motors for every knob display would be too expensive, because I need several of them. Also, the motors will wear out with as much use as I will be giving them, I think. And I don't think the response will be as fast. I can comprise to just 180 degree range, that's ok, but I don't think motors will be good. I want to avoid using a numerical readout from an LCD. If I was able to have some sort of tiny graph bar light up at different values, that would be good too, but not sure if that's possible without using literally thousands of LEDs.
The led matrix with backpack is easy to drive. http://www.adafruit.com/products/871 But may be out of your price range.
We also have inexpensive LED bargraphs, http://www.adafruit.com/products/459
I think I will go with a bar graph LED display after all. I will maybe try and build my own with micro LEDs.
Thank you everyone for your input.
