16-Channel 12-bit PWM/Servo Driver ?
by cwc1885 on Sat Oct 13, 2012 9:48 am
Adafruit 16-Channel 12-bit PWM/Servo Driver - I2C interface - PCA9685
We just purchased 2 16-Channel 12-bit PWM/Servo Drivers.
What size of capacitor is used (shown in the photo?)
http://www.adafruit.com/index.php?main_ ... ge&pID=815
Also: How are two of them connected to control more that 16 servos?
cwc1885
Re: 16-Channel 12-bit PWM/Servo Driver ?
by adafruit_support_bill on Sat Oct 13, 2012 11:19 am
We should have a full tutorial up shortly. In the mean-time:
The capacitor is not essential in most cases. If you see erratic behavior when moving multiple servos at once, you can add some capacitance. Something like a 470-1000uF @6v or more is a good value to start with.
To connect 2 or more in series, just chain the 6-pins one the end of the board to the next board. A 6-pin cable like this makes it easy. Use a bit of solder to bridge the address jumpers on the upper right of the board. For 2 boards, just bridge A0 on the second board. Its I2C address will then be 0x41.
by cwc1885 on Sat Oct 13, 2012 5:02 pm
adafruit_support wrote:We should have a full tutorial up shortly. In the mean-time:
thank you for the help.
we're looking forward to the tutorial
cwc1885
