I2C address
I2C address
by luc on Sat Nov 10, 2012 3:41 pm
Hi friends,
1- Does someone knows if these i2c boards can be used in the same i2c bus?
INA219 High Side DC Current Sensor Breakout - 26V ±3.2A Max
ADXL335 - 5V ready triple-axis accelerometer
BMP085 Barometric Pressure/Temperature/Altitude Sensor
DS1307 Real Time Clock breakout board
they dont have configurable pins i2c address like:
ADS1115 16-Bit ADC - 4 Channel with Progrmmable Gain Amplifier
2 - Does someone knows about add one more "simulated" (but funcional) I2C port in Raspberry pi?
luc
Re: I2C address
by adafruit_support_rick on Sat Nov 10, 2012 5:05 pm
Luc wrote:1- Does someone knows if these i2c boards can be used in the same i2c bus?
They all have different I2C addresses, except for the ADXL335, which is not an I2C device:
INA219 : address 0x40
BMP085 : address 0x77
DS1307 : address 0x68
ADXL335 - three analog outputs.
All three can be used on the same bus.
I have not done this. Someone else may know.
Re: I2C address
by luc on Sat Nov 10, 2012 5:10 pm
Thank you so much.
luc
Re: I2C address
by tldr on Sun Nov 11, 2012 12:50 pm
a while back phil burgess wrote about an i2c bus embedded in the hdmi interface. wonder if that can be gotten at on the pi.
"If I had known it was harmless, I would have killed it myself." - Phillip K. Dick, A Scanner Darkly
tldr
Re: I2C address
by Static on Tue Dec 04, 2012 1:54 pm
During my Raspberry Pi reading, someone posted about nullifying one of the I2C lines (Voltage? Ground?) into an I2C device to enable multiple I2C devices with the same address on the same bus. You'd tie up a GPIO port for each I2C device with a conflicting port, but you should be able to do it.
Static
