Humidity Logger
Humidity Logger
by exp0sure on Wed Nov 14, 2012 7:20 am
I want too hook up 2x humidity sensors to an Arduino and log the data to an SD card. 1 sensor should be in the attic so I would want a wireless connection here. Would it work with the following components?
Arduino
2x Sensiron Temperature/Humidity Sensor - SHT11 (ID: 246)
2x XBee Module - Series 1 (ID: 128)
1x Adafruit Data logging shield (ID: 243)
I haven't used an XBEE yet but do I understand it correctly that I can just hook up a XBEE to the Arduino and one to the Humidity sensor and then simply read/send values to the humidity sensor (those 2 XBEEs create a wireless serial connection)?
To hook up the second serial humidity sensor I'd probably need a second serial port? (either soft port via library or multiplexer to switch between sensors?)
Also can I assume that I can access the RTC in the logging shield to use it as a timer?
Cheers!
exp0sure
Re: Humidity Logger
by adafruit_support_bill on Wed Nov 14, 2012 7:39 am
Yes, this can be done, but I think you need the Series 2 XBee. Here is a nice writeup on how to interface the sensor to the XBee: http://jdesbonnet.blogspot.com/2012/01/ ... ature.html
Since Arduinos are 5v devices and the XBees are 3.3v devices you need something like the XBee adapter to shift the logic levels. https://www.adafruit.com/products/126
You can interface more other remote sensors via the same XBee. A local sensor would require just 2 pins. You can use the RTC on the logger shield for timing.
For a great reference on remote sensing with XBees, I highly recommend Rob Faludi's book:
https://www.adafruit.com/products/963
Re: Humidity Logger
by exp0sure on Wed Nov 14, 2012 4:39 pm
Thanks! I'll have a read...
exp0sure
