Memorial day is 05/25/2015 – Orders will ship out on May 26th. There will not be any deliveries or shipping on Monday. Any order placed after 11am ET on Friday May 22nd will not start to ship out until Tuesday May 26th.
how do I connect unipolar stepper (858) using h-bridge without using shield?
by kelp on Wed Nov 28, 2012 6:37 pm
is this possible ?
https://www.adafruit.com/product/858
I've been reading that it should use darlington array instead (not like I know what that is yet -noob here), but since the adafruit motor shield has h-bridge, I thought there might be a way.
I think these are correct for wire color indications
Coil #1 -- PINK  & ORANGE
Coil #2 -- BLUE & YELLOW
Center Tap -- RED
if it is possible, can someone match those to the L293D assignments ?
thanks.
kelp
Re: how do I connect unipolar stepper (858) using h-bridge without using shield?
by adafruit_support_bill on Thu Nov 29, 2012 7:12 am
You can use either a H-bridge like the L293D or a darlington array like the LN2803
Here is a nice tutorial showing how to connect the L293D. It uses the Stepper library that comes with the IDE: http://www.arduino.cc/en/Tutorial/Stepper
by kelp on Thu Nov 29, 2012 11:16 am
thanks for replying.
i did want to use the arduino.cc tutorial.
i have my board setup like the bipolar layout, because i have a L293D, but then i realized that the diagram is not for a unipolar stepper, and i couldn't find any 5-wire diagrams or advice anywhere.
do the coil wire sets go to all the 'out' pins as in the 'bipolar' diagram, and then where does the center tap, red attach ?
kelp
by adafruit_support_bill on Thu Nov 29, 2012 11:37 am
That is weird. That is a redirect from the tutorial link which showed both wiring diagrams. The original link is gone now.
There is this one: http://www.arduino.cc/en/Tutorial/StepperUnipolar
No wiring diagram, but follow the comments. The center-tap goes to the positive terminal of your power supply. The other wires to the outputs of your bridge.
by kelp on Thu Nov 29, 2012 12:01 pm
great, thanks so much.
kelp
