how do I connect unipolar stepper (858) using h-bridge without using shield?
by kelp on Wed Nov 28, 2012 6:37 pm
is this possible ?
https://www.adafruit.com/product/858
I've been reading that it should use darlington array instead (not like I know what that is yet -noob here), but since the adafruit motor shield has h-bridge, I thought there might be a way.
I think these are correct for wire color indications
Coil #1 -- PINK  & ORANGE
Coil #2 -- BLUE & YELLOW
Center Tap -- RED
if it is possible, can someone match those to the L293D assignments ?
thanks.
kelp
Re: how do I connect unipolar stepper (858) using h-bridge without using shield?
by adafruit_support_bill on Thu Nov 29, 2012 7:12 am
You can use either a H-bridge like the L293D or a darlington array like the LN2803
Here is a nice tutorial showing how to connect the L293D. It uses the Stepper library that comes with the IDE: http://www.arduino.cc/en/Tutorial/Stepper
by kelp on Thu Nov 29, 2012 11:16 am
thanks for replying.
i did want to use the arduino.cc tutorial.
i have my board setup like the bipolar layout, because i have a L293D, but then i realized that the diagram is not for a unipolar stepper, and i couldn't find any 5-wire diagrams or advice anywhere.
do the coil wire sets go to all the 'out' pins as in the 'bipolar' diagram, and then where does the center tap, red attach ?
kelp
by adafruit_support_bill on Thu Nov 29, 2012 11:37 am
That is weird. That is a redirect from the tutorial link which showed both wiring diagrams. The original link is gone now.
There is this one: http://www.arduino.cc/en/Tutorial/StepperUnipolar
No wiring diagram, but follow the comments. The center-tap goes to the positive terminal of your power supply. The other wires to the outputs of your bridge.
by kelp on Thu Nov 29, 2012 12:01 pm
great, thanks so much.
kelp
