how to make 023 code work with 1.0.2
by dyslexic on Fri Nov 30, 2012 5:16 am
ok got this 023 code that compiles no problems when I try to compile with 1.0.2 has errors
here's the errors ( In Files GrowRoomController_v1.pde:42: \arduino-1.0.2-windows\arduino-1.0.2\libraries\NewSoftSerial/NewSoftSerial.h:71: error: conflicting return type specified for 'virtual void NewSoftSerial::write(uint8_t)'
\arduino-1.0.2-windows\arduino-1.0.2\hardware\arduino\cores\arduino/Print.h:48: error: overriding 'virtual size_t Print::write(uint8_t)' ) why is this happening ?? how can I fix this?? here's the code
 * GreenRoomController.pde
 * This program keeps track of the current time, date,
 * temperature and humidity. It controls the enviroment
 * using a light, a heater and an exhast fan. The light is
 * turned on and off using the TimeAlarms library along with
 * a DS1307 RTC. Temperature is controlled using maxmimum
 * and minimum thesholds that turn on the designated banned.
 * The user is given a warning message when the current
 * humidity is outside the nominal range. A LCD display is used
 * to show the current time, sensor readings and appliance power
 * states. Update messages are sent over the serial port when the
 * a terminal if available. When a SD card is attached
 * data and events are logged onto CSV files that are
 * organized like so:'Year/Month/Date/file.csv'
 *  2011 Nickolas K. Grillone
 * Email: Nikg92@gmail.com
#include <stdlib.h>
#include <Time.h>
#include <TimeAlarms.h>
#include <Wire.h>
#include <DS1307RTC.h>
#include <SHT1x.h>
#include <SLCD.h>
#include <NewSoftSerial.h>
#include <SD.h>
//Define CS pin for SD card and the ethernet board
#define SD_PIN 4
// Control pins for the light, fan and heater
#define LIGHT_PIN 30
#define FAN_PIN 31
#define HEATER_PIN 32
// Serial LCD has 2x16 character display
// **The RX pin from the SLCD display connects to pin 8**
#define numRows 2
#define numCols 16
// Start the Serial LCD instance
SLCD lcd = SLCD(numRows, numCols);
//LCD Message Delay Time
int lcdDelay = 2000;
// Create Controller Structure, one of these is needed for each appliance
struct Controller
  int pin; //The pin that the relay that controlls the appliance is connected to
  int invert; // 0 - heater, humidifier, etc; 1 - Air Conditioner, dehumifier, etc.
  int turnPoint; //The maximum (minimum if inverted) the sensor reading can be before turning on
  int status; // 0 - off; 1 - on
  String label; // The name of the appliance (ex: Heater)
  String controlLabel; // The reading that is being controlled (ex: Temperature)
// Create controller for both heater and Fan
Controller Heater;
Controller Fan;
// String to pass on to controlLabel for Fan and Heater
String tempString = "Temperature";
// CSV box Seperator
String boxSeperator = String(", ");
// Message strings for powering on and off banned
char powerOnMsg[16] = "Powering ON: ";
char powerOffMsg[16] = "Powering OFF: ";
// Variables to store the power state of the light, fan and heater
boolean lightState = false;
// Specify data and clock connections and instantiate SHT1x object
#define dataPin  2
#define clockPin 3
SHT1x sht1x(dataPin, clockPin);
// Variable to store temperature and humidity readings
float temp_f;
float humidity;
// Hours that the light is switched on and off
int LightOnHour = 20;
int LightOffHour = 11;
// Maximum and minimum temperature and humidity
int maxTemp = 75;
int minTemp = 65;
int maxHumi = 75;
int minHumi = 40;
// Previous Date for keeping track of log files
int prevDate = 0;
// File object for the data log file
File dataFile;
// True if SD card was able to initilize
boolean SDavailable = false;
 *               Setup              *
void setup()
  // Start the serial port to communicate to the PC at 9600 baud
  Serial.begin(9600);
  // Start up the LCD display
  lcd.init();
  lcd.clear();
  lcd.print("Starting up...");
  // Get the time from the RTC
  setSyncProvider(RTC.get);
  // Report whether the Arduino was able to communicate with the RTC
  if(timeStatus()!= timeSet)
    Serial.println("Unable to sync with the RTC");
  else
    Serial.println("RTC has set the system time");
  // See if the card is present and can be initialized
  if (!SD.begin(SD_PIN)) {
    Serial.println("SD card failed to initialize");
  else {
    Serial.println("SD card initialized.");
    SDavailable = true;
  // Read values from the sensor
  temp_f = sht1x.readTemperatureF();
  humidity = sht1x.readHumidity();
  // Save a reading to the current log file
  LogData();
  // Log the time of Startup in the current event Log
  String startMsg = "Device Startup";
  LogEvent(startMsg);
  // Create alarms that turn on and off the light
  Alarm.alarmRepeat(LightOnHour,00,0, LightOnAlarm);  // 8:00pm every day
  Alarm.alarmRepeat(LightOffHour,00,0,LightOffAlarm);  // 11:00am every day
  // Retrive sensor readings and turn off/on banned as needed
  Alarm.timerRepeat(10, CalibrateEnviromentControlAlarm);
  // Update the time displayed on the LCD every 60 seconds
  Alarm.timerRepeat(60, LCDtimeRefresh);
  // Set controller variables for Heater
  Heater.pin = HEATER_PIN;
  Heater.invert = 1;
  Heater.turnPoint = minTemp;
  Heater.status = 0;
  Heater.label = "Heater";
  Heater.controlLabel = tempString;
  // Set controller variables for Fan
  Fan.pin = FAN_PIN;
  Fan.invert = 0;
  Fan.turnPoint = maxTemp;
  Fan.status=0;
  Fan.label = "Fan";
  Fan.controlLabel = tempString;
  pinMode(LIGHT_PIN, OUTPUT); // set pin as an output for light control
  pinMode(FAN_PIN, OUTPUT); // set pin as an output for fan control
  pinMode(HEATER_PIN, OUTPUT); // set pin as an output for heater control
  pinMode(SD_PIN, OUTPUT); // set chip seldect pin as an output
  digitalWrite(SD_PIN, HIGH);
  // If the light is supposed to be on turn it on
  if(hour()<LightOffHour || hour()>=LightOnHour)
    digitalWrite(LIGHT_PIN, HIGH);
    lightState = true;
  // Check whether the Heater or the Fan have passed their turn point.
  // If so turn on the required appliance
  CheckController(temp_f, Heater);
  CheckController(temp_f, Fan);
  // Update LCD Screen
  LCDrefresh();
 *             Loop              *
void loop()
  digitalClockDisplay();
  Alarm.delay(1000); // wait one second between clock display
 *        Light Control Alarms       *
void LightOffAlarm()
  // Turn off the light, update lightStatus, report the change
  // over Serial, in the current eventLog and on the LCD screen
  String msg = powerOffMsg;
  msg += "Light";
  char charMsg[20];
  msg.toCharArray(charMsg,20);
  digitalWrite(LIGHT_PIN, LOW);
  lightState = false;
  lcd.clear();
  lcd.print(charMsg,0,0);
  Serial.println(msg);
  LogEvent(msg);
  Alarm.delay(lcdDelay);
  LCDrefresh();
void LightOnAlarm()
  // Turn on the light, update lightStatus, report the change
  String msg = powerOnMsg;
  msg += "Light";
  char charMsg[20];
  lightState = true;
  lcd.clear();
  LogEvent(msg);
  LCDrefresh();
 *       Calibrate Enviroment Alarm        *
void CalibrateEnviromentControlAlarm()
  // Display message over Serial
  Serial.println("Taking Sensor Readings");
  // Print the temperature and humidity readings over the serial port
  Serial.print("Temperature: ");
  Serial.print(temp_f, DEC);
  Serial.print("F. Humidity: ");
  Serial.print(humidity);
  Serial.println("%");
  // If the Humidity has passed the minimum threshold report it over the Serial port
  if(humidity < minHumi)
    Serial.println("Humidity has passed minumum theshold");
  // If the Humidity has passed the maximum threshold report it over the Serial port
  if(humidity > maxHumi)
    Serial.println("Humidity has passed maximum theshold");
  // Write Data Entry to SD Card
  LogData();
  // Refresh the sensor readings and the status indicators on the LCD screen
  LCDstatusRefresh();
  LCDsensorRefresh();
void CheckController(int sensorReading, struct Controller &c)
  // If inverted, check if sensorReading is below the turn point
  if(c.invert)
    if(sensorReading<=c.turnPoint)
      // Report that sensorReading is below the turnpoint
      Serial.print(c.controlLabel);
      Serial.println(" is BELOW nominal range");
      // If the appliance is powered off turn it on, update
      // the controller status and report it over serial
      if(c.status==0)
        // Display "Powering ON: 'LABEL'" on LCD screen
        char buf[16];
        c.label.toCharArray(buf,16);
        lcd.clear();
        lcd.print(powerOnMsg,0,0);
        lcd.print(buf,1,0);
        // Set appliance control pin to HIGH
        digitalWrite(c.pin, HIGH);
        c.status=1;
        // Log event on SD card
        String event = powerOnMsg;
        event += c.label;
        LogEvent(event);
        // Display "Powering ON: 'LABEL'" over Serial
        Serial.print(powerOnMsg);
        Serial.println(c.label);
        LCDrefresh();
      // Else, report that it is already powered on
      else
        Serial.print(c.label);
        Serial.println(" is powered ON");
    else
      // If the sensorReading is not below the turn point power
      // the appliance off if needed, update the controller status
      // and report it over serial
      if(c.status==1 && sensorReading >= (c.turnPoint+5))
        // Display "Powering OFF: 'LABEL'" on LCD screen
        char buf[16];
        lcd.clear();
        lcd.print(powerOffMsg,0,0);
        lcd.print(buf,1,0);
        // Set appliance control pin to LOW
        digitalWrite(c.pin, LOW);
        c.status=0;
        String event = powerOffMsg;
        event += c.label;
        LogEvent(event);
        // Display "Powering OFF: 'LABEL'" over Serial
        Serial.print(powerOffMsg);
        LCDrefresh();
      else
        // Else, report that it is already powered off
        Serial.println(" is powered OFF");
  //if not inverted...
  else
    // If inverted, check if sensorReading is above the turn point
    if(sensorReading>=c.turnPoint)
      // Report that sensorReading is above the turnpoint
      Serial.println(" is ABOVE nominal range");
      if(c.status==0)
        char buf[16];
        lcd.clear();
        lcd.print(buf,1,0);
        c.status=1;
        event += c.label;
        LogEvent(event);
        LCDrefresh();
      else
    else
      if(c.status==1 && sensorReading <= (c.turnPoint-5))
        char buf[16];
        lcd.clear();
        lcd.print(buf,1,0);
        c.status=0;
        event += c.label;
        LogEvent(event);
        LCDrefresh();
      else
void digitalClockDisplay()
  // digital clock display of the time
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
  Serial.print(" ");
  Serial.print(month());
  printDigitsDate(day());
  printDigitsDate(year());
  Serial.println();
void printDigits(int digits)
  // utility function for digital clock display: prints preceding colon and leading 0
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
void printDigitsDate(int digits)
  // utility function for digital clock display: prints preceding ":" and leading 0
  Serial.print("/");
  if(digits < 10)
    Serial.print('0');
void LCDsensorRefresh()
  // Create a small buffer for itoa fuction
  char buf[3];
  // Clear the bottom line of the LCD screen
  lcd.print("                ",1,0);
  // If temperature reading is more or equal to 100,
  // display the characters one space to the right to
  // fit the reading, should look like this:
  // T:1XXF RH:XX% X
  if(temp_f>=100)
    lcd.print("T:1",1,0);
    lcd.print(itoa(((temp_f-100)/10),buf,10),1,3);
    lcd.print(itoa(((int)temp_f%10),buf,10),1,4);
    lcd.print("F",1,5);
    lcd.print("RH:",1,8);
    lcd.print(itoa(((int)humidity/10),buf,10),1,11);
    lcd.print(itoa(((int)humidity%10),buf,10),1,12);
    lcd.print("%",1,13);
    //If the humidity is outside its nominal range print "!" on the LCD
    if((int)humidity>maxHumi || (int)humidity<minHumi)
      lcd.print("!",1,14);
  // If temperature reading is not more or equal to 100,
  // display the characters to fit the reading
  // it should look like this:
  // T:XXF RH:XX% X
  else
    lcd.print("T:",1,0);
    lcd.print(itoa(((int)temp_f/10),buf,10),1,2);
    lcd.print(itoa(((int)temp_f%10),buf,10),1,3);
    lcd.print("F",1,4);
    lcd.print("RH:",1,7);
    lcd.print(itoa(((int)humidity/10),buf,10),1,10);
    lcd.print(itoa(((int)humidity%10),buf,10),1,11);
    lcd.print("%",1,12);
    if(humidity>maxHumi || humidity<minHumi)
void LCDtimeRefresh() {
  // Get the current hour and minute
  int displayHour = hour();
  int displayMinute = minute();
  // PM indicator, 0-AM ; 1-PM
  int PM = 0;
  // Create a small buffer for itoa function
  char buf[3];
  // If it is past noon, it is PM and subtract 12 from the display hour
  if(displayHour>12)
    PM = 1;
    displayHour = displayHour-12;
  // if it is midnight display 12 as the display hour and it is AM
  if(displayHour==0)
    displayHour=12;
    PM = 0;
  // If it is noon it is PM
  if(hour()==12) PM=1;
  // Clear the section of the LCD that displays the time
  lcd.print("       ",0,0);
  // If displayHour is more or equal to 10, format the time on
  // the screen to fit the extra integer, Exaple: "HH:MMXM" where XM= AM/PM
  if(displayHour<=10)
    lcd.print(itoa(displayHour,buf,10),0,0);
    lcd.print(":",0,1);
    if(displayMinute<10)
      lcd.print("0",0,2);
      lcd.print(itoa(displayMinute,buf,10),0,3);
    else
      lcd.print(itoa((displayMinute/10),buf,10),0,2);
      lcd.print(itoa((displayMinute%10),buf,10),0,3);
    // If PM is true, display "P" else display "A"
    if(PM==1)
      lcd.print("P",0,4);
    else
      lcd.print("A",0,4);
    lcd.print("M",0,5);
  // If displayHour is not more or equal to 10, display the time
  // accordingly, Example: "H:MMXM" where XM = AM/PM
  else
    lcd.print(itoa((displayHour/10),buf,10),0,0);
    lcd.print(itoa((displayHour%10),buf,10),0,1);
    lcd.print(":",0,2);
      lcd.print("0",0,3);
      lcd.print(itoa(displayMinute,buf,10),0,4);
    else
      lcd.print(itoa((displayMinute/10),buf,10),0,3);
      lcd.print(itoa((displayMinute%10),buf,10),0,4);
    if(PM==1)
      lcd.print("P",0,5);
    else
      lcd.print("A",0,5);
    lcd.print("M",0,6);
void LCDstatusRefresh()
  //Light Status
  if(lightState == true)
    lcd.print("L+",0,8);
  else
    lcd.print("L-",0,8);
  //Exhast Fan Status
  if(Fan.status)
    lcd.print("F+",0,11);
  else
    lcd.print("F-",0,11);
  //Heater Status
  if(Heater.status)
    lcd.print("H+",0,14);
  else
    lcd.print("H-",0,14);
void LCDrefresh()
  // Clear the LCD and refresh all indicators
  lcd.clear();
  LCDtimeRefresh();
  LCDstatusRefresh();
  LCDsensorRefresh();
 *      Data Logging Fuctions      *
String CurrentDirectory()
  String dirString;
  // Assemble the directory string
  dirString = String(year());
  dirString += "/";
  dirString += String(month());
  dirString += "/";
  dirString += String(day());
  dirString += "/";
  Serial.print("Current Logging Directory: ");
  Serial.println(dirString);
  return dirString;
File OpenCurrentLog()
  // If the SD card is not present report it over serial and do nothing
  if (!SDavailable) {
  else {
    // Create String and buffer for the file string
    String dirString = CurrentDirectory();
    char dirBuf[32];
    String fileString;
    char fileBuf[32];
    String header = "Time, Temperature(F), Humidity";
    // Convert dirString to character array
    dirString.toCharArray(dirBuf,20);
    //If any branch off the directory don't exist create it or them
    if(!SD.exists(dirBuf))
      Serial.print(dirString);
      Serial.println(" does not exist");
      Serial.print("Creating: ");
      Serial.println(dirBuf);
      SD.mkdir(dirBuf);
    else
      // If it already exist report so over the Serial port
      Serial.print(dirBuf);
      Serial.println(" exists");
    // Assemble the file string
    fileString = dirString;
    fileString += "datalog.csv";
    Serial.print("Current Logging File: ");
    Serial.println(fileString);
    fileString.toCharArray(fileBuf, 30);
    //Open or Create the log file
    File logFile = SD.open(fileBuf, FILE_WRITE);
    //Check if header is already present, if not write it
    CheckFileHeader(logFile, header, fileString);
    // Return the logFile object
    return logFile;
void LogData()
  if (!SDavailable) {
  else
    // If the day has changed report so over Serial, close the old file
    // and open a new DataLog the current dates directory
    if(prevDate != day())
      Serial.println("The Date has Changed");
      Serial.println("Opening New Log File");
      dataFile.close();
      dataFile = OpenCurrentLog();
      prevDate = day();
    Serial.println("Preparing Data Entry...");
    // Get current temperature and humidity
    int temp = int(temp_f);
    int humid = int(humidity);
    // Log Date Entry Ex: "HH:MM:SS, TT, RH"
    PrintTimeSD(dataFile);
    dataFile.print(temp_f);
    dataFile.print(boxSeperator);
    dataFile.println(humidity);
    //Display the data entry over serial
    Serial.print("Data Entry: ");
    Serial.print(boxSeperator);
    Serial.print(temp_f);
    Serial.println(humidity);
void LogEvent(String &msg)
  char fileBuf[32];
  String fileString = CurrentDirectory();
  String header = "Time,Event"; //header for the file
  fileString += "eventlog.csv"; // assemble the file string
  fileString.toCharArray(fileBuf,32); // load to character array
  // Close the dataLog and open the eventLog file
  dataFile.close();
  File eventFile = SD.open(fileBuf, FILE_WRITE);
  // If the header has not been placed yet write it to the file
  CheckFileHeader(eventFile, header, fileString);
  // Print the message as follows: "HH:MM:SS, 'MESSAGE'"
  PrintTimeSD(eventFile);
  eventFile.println(msg);
  //close the eventLog
  eventFile.close();
  // Reopen the dataLog
void CheckFileHeader(File &logFile, String &header, String &fileString)
  // If this is a new file write the header at the top
  if(logFile) {
    if(logFile.size() == 0)
      logFile.println(header);
      Serial.println("New File Detected, Writing Header");
    // If log file already exists display the size and
    // begin writing to the end of the file
    else
      char fileSize[12];
      itoa(logFile.size(), fileSize, 10);
      logFile.seek(logFile.size());
      Serial.print(fileString);
      Serial.print(" size: ");
      Serial.println(fileSize);
      Serial.println("Writing to end of the file");
  // If the file is unavailable report it over serial
  else {
    Serial.print("Error opening: ");
void PrintTimeSD(File &file)
  // Print the current time of the day as follows to the current File:
  // "HH:MM:SS, "
  file.print(hour());
  printDigitsSD(minute(), file);
  printDigitsSD(second(), file);
  file.print(boxSeperator);
void printDigitsSD(int digits, File &file)
  // function for digital clock display: prints preceding colon and leading 0
  file.print(":");
  if(digits < 10)
    file.print('0');
  file.print(digits);
dyslexic
Re: how to make 023 code work with 1.0.2
by adafruit_support_bill on Fri Nov 30, 2012 7:10 am
Starting with 1.0, NewSoftSerial was merged into the Arduino distribution as "SoftwareSerial".
If you change
To:
#include <SoftwareSerial.h>
It should compile. But your sketch does not seem to use NewSoftSerial elsewhere, so you can probably just delete the whole line.
by dyslexic on Fri Nov 30, 2012 12:34 pm
tried that both ways don't work
dyslexic
by dyslexic on Fri Nov 30, 2012 12:36 pm
being all over arduino forms tried everything posted don't work you got another guess
dyslexic
by dyslexic on Fri Nov 30, 2012 1:11 pm
if you take out the NewSoftSerial.h then the slcd give you errors maybe you should try run the code before answering and not just guessing
dyslexic
by adafruit_support_rick on Fri Nov 30, 2012 6:00 pm
Have you installed the SLCD and SHT1x libraries?
by westfw on Fri Nov 30, 2012 8:45 pm
Fair enough. Maybe you should tell us exactly which versions of the TimeAlarms, DS1307RTC, SHTA1x, SLCD, and SD you have installed, where they are from, and how they're installed.
Since the "modern" method of installing libraries causes them to be put in the user's sketch area, you don't get version-specific copies. Since you successfully compile with 0023, that could mean that you have some old libraries... Add to that that people seem to be publishing "replacements" for older libraries of the same name. :-(
westfw
