Why voltage divider for resistive sensors?
by relaxing on Sun Dec 02, 2012 2:39 pm
Excuse my basic theory question, but...
I've read the Wikipedia article on voltage dividers and I'm pretty sure I understand what they do. But why do we build them into sensor circuits?
I've built Arduino circuits like...
5V------thermistor------Analog In
And they work.
So why is it better to do
5V------thermistor------Analog In------resistor-----GND
relaxing
Re: Why voltage divider for resistive sensors?
by adafruit_support_bill on Sun Dec 02, 2012 3:24 pm
This app note describes the pros & cons of various thermistor circuit configurations:
http://ww1.microchip.com/downloads/en/a ... 00685b.pdf
by relaxing on Sun Dec 02, 2012 4:16 pm
So the answer is linearization?
Is it fair to say if I'm unconcerned with linear response, I can still hook up my sensor to a GPIO without also connecting it to ground?
relaxing
by adafruit_support_bill on Sun Dec 02, 2012 6:08 pm
If you have nothing connected to the input of an analog pin, it 'floats' and you get nothing but noise. If you connect a fixed pullup or pulldown resistor of sufficient strength (strong = low value) you get 5v (pullup) or 0v (pulldown). If you connect a variable resistor (e.g. a thermistor) between the analog pin 5v, you will get 5v at low values (strong pullup) and 'float' at high values (weak pullup). So the resistor is about more than just linearization.
