Adding Battery Pack to RC Car
by JRMN on Mon Dec 03, 2012 12:28 pm
I recently bought an old 1991 Tyco RC Fast Traxx car from eBay. I got a really good deal on the car because didn’t come with a battery pack and charger. I know it original came with a NiCd 9.6V 700mAh battery, going to replace it with 9.6V 1600mAh or 2000mAh Ni-MH battery pack.
I also have a Spy Gear TRAKR that takes six AA batteries. I would like to wire up the TRAKR to use the same battery pack that I am going to get for my Tyco Fast Traxx. I’m not too worried about opening the TRAKR because it’s well documented and I know Radio Shack sells the connector I need.
Is there anything that I sure be worried about and would using the 9.6V battery pack fry my TRAKR? Thanks
JRMN
Re: Adding Battery Pack to RC Car
by adafruit_support_bill on Mon Dec 03, 2012 1:02 pm
6x alkaline AAs will give you close to 9.6v when fresh. But a freshly charged 9.6v NiMH pack will be more like 11.2v. I don't know how tolerant the trakr is of overvoltage. But to be safe, you could always put a diode in line to drop the voltage a little.
by JRMN on Mon Dec 03, 2012 1:43 pm
That's what I was afraid of. What about a 3 Amp UBEC (I still need to read up on it)? I just read that's what most RC people use. Is there any way I can find out if the TRAKR has a voltage regulator built-in and how many amps the TRAKR draws?
JRMN
by adafruit_support_bill on Mon Dec 03, 2012 1:58 pm
A UBEC should work. I'd expect 3A is enough. Unless it is published somewhere, the best way to find out the actual current draw is to measure it. http://learn.adafruit.com/multimeters/current
by JRMN on Mon Dec 03, 2012 4:21 pm
Thanks for the link, I will read up on it tonight. This is what I do know, the H-bridge driver circuit is made up of B772 (lower row) and D882 (upper row) transistors with a 7805 voltage regulator (5V fixed) on one end.
JRMN
by adafruit_support_bill on Mon Dec 03, 2012 4:53 pm
7805's are good for up to 1A, but I suspect that is just for powering the logic. B772s and D882s are rated for up to 3A.
