Re-Build of Solar lipo charger
by volker_doelling on Mon Dec 03, 2012 1:47 pm
Hello !
I am thinking of building the solar charger on my own, thanks to the open source nature of Product ID 390, which is solar, usb, dc lipo charger.
I would like t buy the MCP 73871. There are different "versions" which you can buy?
My question is:
What does the "2CCi/ML" part in this product name do ? : MCP73871-2CCI/ML
According to the manufacturer MCP there are different names of the MCP chip. Which version do you use in you adafruit product ?
Thank you very much for you answers.
Best greetings from germany.
Volker Dölling
volker_doelling
Re: Re-Build of Solar lipo charger
by volker_doelling on Tue Dec 04, 2012 1:02 pm
Hi there,
are there any informations missing, i should provide ?
volker_doelling
by adafruit_support_bill on Tue Dec 04, 2012 1:38 pm
The identification markings are described in section 7 of the data sheet: http://www.adafruit.com/datasheets/MCP73871.pdf
by blbeggs on Tue Dec 04, 2012 9:20 pm
The datasheet isn't very helpful. But the best I can determine is that the suffix on the part number is an arbitrary identification value and the chips all perform exactly the same.
Also, I am trying to re-build the same charger and I have downloaded the eagle files. When I opened the .brd file I noticed a 0 ohm resistor floating at the bottom that appears to disable the USB charging. Have you noticed this? If so what is going on there?
blbeggs
by adafruit_support_bill on Tue Dec 04, 2012 9:56 pm
It is actually pretty specific. See page 35.
by blbeggs on Fri Dec 07, 2012 4:43 pm
Oh yep page 35 is much more helpful than 29, thanks. Which model does adafruit use? Also, any insight on what is going on with the floating 0 ohm resistor in the .brd file for this board? Is it an error?
https://github.com/adafruit/USB-DC-Solar-Lithium-Ion-Polymer-charger
blbeggs
by adafruit_support_bill on Fri Dec 07, 2012 6:41 pm
We use the 2CC version. Not sure why the 0-ohm D2 is not properly placed, but the connections are correct as can be seen on the schematic and the photo on the catalog page.
