TSL2561 query
TSL2561 query
by tusshar on Tue Dec 04, 2012 5:49 am
ir = lum >> 16;// what does this mean cant get the syntax?
full = lum & 0xFFFF; //what does this mean cant get the syntax?
tusshar
Re: TSL2561 query
by tusshar on Tue Dec 04, 2012 6:07 am
Also the sensor is giving me 0 luminosity. Even when the sensor is disconnected and i run the code it gives found sensor.
tusshar
Re: TSL2561 query
by adafruit_support_bill on Tue Dec 04, 2012 7:43 am
That is a binary shift operation. It shifts the value right by 16 bits (equivalent to a divide by 65535)
That is a binary masking operation using a logical AND (&). It masks off everything but the low order 16 bits.
Post photos showing all your connections and we'll take a look.
Re: TSL2561 query
by tastewar on Tue Dec 04, 2012 10:48 am
Minor correction -- it's a divide by 65536.
Seems like lum is a 32-bit variable that really contains 2 16-bit "fields" of information: the upper 16 bits would appear to encode ir luminosity, and the lower 16 bits would appear to encode full spectrum luminosity. (This is what I infer from the code and no other context -- could be complete BS...) The two operations are intended to isolate those two numbers into their own variables.
tastewar
Re: TSL2561 query
by tusshar on Wed Dec 05, 2012 2:44 am
Posting Pics...
tusshar
Re: TSL2561 query
by adafruit_support_bill on Wed Dec 05, 2012 7:22 am
The I2C bus on an UNO is on analog pins 4 and 5. The correct wiring is:
http://learn.adafruit.com/tsl2561/wiring
Re: TSL2561 query
by tusshar on Wed Dec 05, 2012 11:14 am
Ooooooooooo. :| Thanks sorry my first I2C sensor.
tusshar
