MPPT for wind turbine
by GoVertical0017 on Wed Dec 12, 2012 10:08 pm
Greetings, I am working on a MPPT controller for a wind turbine. I have the DC to DC converter working and I am able to manually adjust the duty cycle of the buck converter from 10 to 50 percent.
The next step of the project is to add a micro to control the duty cycle of buck converter. This is where I need help. I have to read the voltage and current at the input and output. I am using a Arduino UNO.
Max voltage is 400 Vdc at the input of the buck converter.
Buck converter max current is 20 amps.
Any help received will be greatly appreciated. What methods should I use for reading the voltage and current?
Buck converter with manual control for duty cycle
Vertical Axis Wind Turbine
F&P PMA
GoVertical0017
Re: MPPT for wind turbine
by GoVertical0017 on Wed Dec 12, 2012 10:45 pm
Hi, photos of buck converter circuit for project.
The buck converter is four 5 amp DC to DC converters connected in parallel. I am using the IRF840 mosfet. I am using a F&P axial flux motor as a 3 phase permanent magnet alternator that generates about 1 volt per RPM. Because it is possible to generate a very high voltage I have included a over voltage protection circuit.
Requesting suggestions for sensing current and reading voltage at the input and output that can interface with a UNO.
buck converter
Buck converter circuit
Last edited by GoVertical0017 on Wed Dec 12, 2012 11:50 pm, edited 1 time in total.
GoVertical0017
by john444 on Wed Dec 12, 2012 11:06 pm
Hi GoV,
Your VAT looks great.
I was going to suggest the Adafruit INA219 High Side DC Current Sensor.
The 20-A will not be a problem with a shunt-resistor change.
However, it will not be usable unless you were to use it on the 12-V side
of your circuit.
At 400-V you need good isolation! Maybe you would want to consider
sensing on the AC side of the alternator:
A current transformer or Hall effect will provide the Amp measurement.
A voltage-transformer for voltage.
These will provide the isolation you need and you can work with signal levels
an Arduino can handle. Especially since you do not need milli-Sec speeds.
Good Luck, John
john444
by john444 on Wed Dec 12, 2012 11:11 pm
GoV,
I see you posted again before I finished composing my response to your
first post. :)
Why 4 buck-converters? Why not just one capable of 20-A?
John
john444
by GoVertical0017 on Thu Dec 13, 2012 12:01 am
john444 wrote:GoV,
first post. :)
John
Hi, I tried paralleling the mosfets and at higher amperage the board became hot, sometimes to hot. A 20 inductor is to expensive for the project. I have had very good results with the 5 amp versions, it stays cool. The max current for each board 6 amps but I am limiting the project to 15 amps total.
This a first time attempting at this kind of project and I am searching for other project that read voltage and sense current using a UNO. Thank you for the suggestions.
GoVertical0017
by john444 on Fri Dec 14, 2012 12:47 pm
GoV,
GoVertical0017 wrote:I tried paralleling the mosfets and at higher amperage the board became hot
If each FET had it's own driver, paralleling should have worked fine.
GoVertical0017 wrote:A 20 inductor is to expensive
Is it 4x as expensive as four 5-A inductors?
GoVertical0017 wrote:I have had very good results with the 5 amp versions, it stays cool.
That is good. However, sometimes units conflict with each other. If yours don't you are good.
What do you think? measure high-side AC or low-side DC?
John
john444
by GoVertical0017 on Fri Dec 14, 2012 11:37 pm
Hi, the only 20 amp inductor I could find cost 200.00 US. I have purchased some small current sensing transformer. The buck converters will always operate in discontinues mode so I think it will work at the AC input and the DC output. I am currently building and new permanent magnet alternator that I can operate using a hand crank then I can start testing some simple circuits and determine the max and min values. I plan to use just one buck converter to interface with the UNO and use software to multiply the values for the hole system. I will post results when available, thanks for taking a interest in the project. I am using a blocking diode at the output of each buck converter.
http://ww2.pulseeng.com/products/datasheets/P578.pdf
current sense transformer
GoVertical0017
by GoVertical0017 on Sat Dec 15, 2012 8:08 am
http://jarv.org/2009/07/home-power-monitoring/
Hi, I found this project that is very similar to what I am working on. They interface the CT to the Arduino using just a 5 Kohm resistor, can it really be that simple??????
GoVertical0017
by john444 on Sat Dec 15, 2012 10:47 am
GoV,
GoVertical0017 wrote:They interface the CT to the Arduino using just a 5 Kohm resistor, can it really be that simple??????
Almost. I would include a couple of blue LED's or zeners to put a limit to the voltage the CTs can put out.
With a properly chosen CT and load resistor, it is simple - AC-A in / AC-V out.
Good Luck, John
john444
by lemming86_au on Wed Jan 09, 2013 2:30 am
GoV,
That's a great looking VAWT you are building! Are you documenting your project somewhere that we can take a look at?
Regards,
Josh
lemming86_au
by GoVertical0017 on Wed Jan 09, 2013 5:28 pm
http://www.vawts.net/t37175103/started-new-vawt-proto-type/
Hi, the above link is the most complete. I have been working on the project for a number years. Adding the MPPT circuit will offer the greatest benefit. Thank for the interest.
GoVertical0017
