I'm not having much success. I believe this is because I'm messing up the swapping of the least significant bit and most significant bit.
#!/usr/bin/python
import time
from Adafruit_I2C import Adafruit_I2C
class TMP102 :
i2c = None
# Constructor
def __init__(self, address=0x48, mode=1, debug=False):
self.i2c = Adafruit_I2C(address)
self.address = address
self.debug = debug
# Make sure the specified mode is in the appropriate range
if ((mode < 0) | (mode > 3)):
if (self.debug):
print "Invalid Mode: Using STANDARD by default"
self.mode = self.__BMP085_STANDARD
else:
self.mode = mode
def readRawTemp(self):
"Reads the raw (uncompensated) temperature from the sensor"
raw = self.i2c.readU16(0x48) #The TMP102 returns 12-bits, I think
raw = self.i2c.reverseByteOrder(raw) #I need to get the bit order reveresed
if (self.debug):
print "DBG: Raw Temp: 0x%04X (%d)" % (raw & 0xFFFF, raw)
return raw
def readTemperature(self):
"Gets the compensated temperature in degrees celcius"
RawBytes = self.readRawTemp() #get the temp from readRawTemp (above)
temp = float(RawBytes) *0.0625 #this is the conversion value from the data sheet.
if (self.debug):
print "DBG: Calibrated temperature = %f C" % temp
return RawBytes,temp
I'm getting values that change with the temp, but they're incredibly high.
Static
