TMP102 on a Raspberry Pi using Python
by Static on Fri Dec 14, 2012 8:50 pm
I'm trying to expand the Adafruit I2C Python Library.
I'm not having much success. I believe this is because I'm messing up the swapping of the least significant bit and most significant bit.
#!/usr/bin/python
import time
from Adafruit_I2C import Adafruit_I2C
class TMP102 :
  i2c = None
  # Constructor
  def __init__(self, address=0x48, mode=1, debug=False):
    self.i2c = Adafruit_I2C(address)
    self.address = address
    self.debug = debug
    # Make sure the specified mode is in the appropriate range
    if ((mode < 0) | (mode > 3)):
      if (self.debug):
        print "Invalid Mode: Using STANDARD by default"
      self.mode = self.__BMP085_STANDARD
    else:
      self.mode = mode
  def readRawTemp(self):
    "Reads the raw (uncompensated) temperature from the sensor"
    raw = self.i2c.readU16(0x48)     #The TMP102 returns 12-bits, I think
    raw = self.i2c.reverseByteOrder(raw)  #I need to get the bit order reveresed
    if (self.debug):
      print "DBG: Raw Temp: 0x%04X (%d)" % (raw & 0xFFFF, raw)
    return raw
  def readTemperature(self):
    "Gets the compensated temperature in degrees celcius"
    RawBytes = self.readRawTemp()  #get the temp from readRawTemp (above)
    temp = float(RawBytes) *0.0625  #this is the conversion value from the data sheet.
    if (self.debug):
      print "DBG: Calibrated temperature = %f C" % temp
    return RawBytes,temp
This doesn't look like it is too complicated. That being said, i've been plugging away at this for hours. If anyone has any ideas, I'm more than happy to try them.
I'm getting values that change with the temp, but they're incredibly high.
Thanks,
Static
Static
Re: TMP102 on a Raspberry Pi using Python
by Static on Fri Dec 14, 2012 10:39 pm
I modified the code a little bit. First, I did away with the "Reverse Byte Order" conversion. Next, I bit shifted the raw temp over four bits. That got me something that looks closer to the temperature. However, it always seems to end in a .375. The temperature is very close to the temp that I'm getting from the BMP085 that is sitting 15 centimeters away from it (and two and a half meters of cabling away).
I'm not sure that I'm correct here. Can anyone check this code?
#!/usr/bin/python
import time
class TMP102 :
  i2c = None
  # Constructor
    self.debug = debug
      if (self.debug):
    else:
      self.mode = mode
    #raw = self.i2c.reverseByteOrder(raw)  #I need to get the bit order reveresed
    if (self.debug):
    return raw
    RawBytes = (RawBytes >> 4)
    if (self.debug):
Static
by pwootton on Wed Mar 13, 2013 10:20 pm
Try this
#!/usr/bin/python
import time
# Tmp102 Class
class Tmp102:
  i2c = None
  # Constructor
    self.i2c = Adafruit_I2C(address, debug=debug)
    self.debug = debug
      if (self.debug):
    else:
      self.mode = mode
    self.i2c.write8(0, 0x00)                 # Set temp reading mode
    raw = self.i2c.readList(0,2)
    val = raw[0] << 4;
    val |= raw[1] >> 4;
    return val
    temp = float(float(RawBytes) * 0.0625)  #this is the conversion value from the data sheet.
    if (self.debug):
      print "DBG: Raw Temp: 0x%04X (%d)" % (RawBytes & 0xFFFF, RawBytes)
if __name__ == "__main__":
  import time
  mytemp = Tmp102(address=0x48)
  print mytemp.readTemperature()[1]
I'm not sure what the mode stuff on the constructor is for, but the crucial change is reading the 2 data bytes in a readList, rather than as U16 (or S16 or 2*U8 or 2*S8)
-- Paul --
pwootton
by Static on Thu Mar 14, 2013 7:34 am
I just updated to the new Adafruit I2C code. I need to look at how the changes are propagating through my code. Right now, it looks like the readlist() addition improves the quality of the data coming from the sensor. However, it looks like the new Adafruit code breaks my other sensors. I'm getting bizarre data from them.
Thanks for checking my work. I knew there was something hinky there, I just wasn't seeing how the bit shift worked.
Static
by Static on Fri Mar 15, 2013 1:00 pm
I haven't seen that final code snippet before. I like that a lot. That's going to save me soooo much time troubleshooting and deploying code.
What's the [1] for here?
The constructor passes self (needed), the default address, mode (this is junk code from when I used the BMP085 code as a basis for this, it doesn't do anything here), debug (this is going to be passed down the code to the I2C code when I clean things up). I need to add the bus number to the constructor, as it's pretty easy to use both buses on the Pi. I've re-written my code, but I'm error checking it today. I need to clean it up and re-list it.
I seem to be getting weird values since I switch to the new Adafruit_I2C code (the "ReadList" function wasn't available before). Currently my office is reading as 131.4 degrees Celsius... I'm still alive and pretty comfortable, so that's not right. It's reading my external temp as too high as well (two different sensors, internal is the BMP085, external is the TMP102). My light sensors are also acting wonky.
More as I get it.
Static
