on ebay, i am noticing tact switches that are all different...
some have 4 pins while others have 6 pins.. and they have different sizes too.
6 x 6 x 5mm (which i have 50 of)
then i am seeing:
7 x 7 x 16mm
8.5 x 8.5 x 14mm
8.5 x 8.5 x 21mm
12 x 12 x 9mm
and so on.. what are the differences of the pins 4 and 6 and why so many sizes?
thanks
differences in tact switches
- Franklin97355
Re: differences in tact switches
As to the pins you would have to check the pinouts or schematics. The sizes are so they fit the product design parameters.what are the differences of the pins 4 and 6 and why so many sizes?
- zener
I never saw any 6 pin ones, mostly 4, and some 2. They are generally square which is why the first two dimensions are the same. The last dimension is usually the height, since they have different length buttons on them, necessary for different applications.
@zenerI never saw any 6 pin ones
here's some, but there are more..
- zener
In my experience a tact switch refers to a SPST NO switch with tactile feedback and no maintained or alternating action.
Those 6 pin ones are probably DPDT pushbutton switches.
