Hi everyone,
I've got an TMP36 attached to an arduino Mega 2560 on Analog pin 0, getting the ground and 5v from the card.
When reading, I get the readings 177 from the board.
Nomatter how I try to convert this to Celicius, I get really odd values since it indicates +33 degress celcius.
In the room, I've got top 22 degrees.
I've tried numerous different sensors (all Tmp36's) but still the same readings.
What am I doing wrong?????
Thanks in advance!
/Karl
TMP36, odd readings...
- zener
Re: TMP36, odd readings...
Need more info. What is the raw reading? Post your code in a code box. How do you display or determine the final temperature value?
Below is some other code I found while googling. It's closer to reality but still off quite a bit.
I've checked and the current temp in the room (right next to the TMP36) is 21degrees.
The output from the code below is:
175 reading, 3.61 V power supply, 0.62 volts, 11.66 degrees C
174 reading, 3.79 V power supply, 0.64 volts, 14.33 degrees C
175 reading, 3.76 V power supply, 0.64 volts, 14.25 degrees C
#define BANDGAPREF 14
int refReading = analogRead(BANDGAPREF);
// now calculate our power supply voltage from the known 1.05 volt reading
float supplyvoltage = (1.05 * 1024) / refReading;
//getting the voltage reading from the temperature sensor
int reading = analogRead(sensorPin);
// converting that reading to voltage
float voltage = reading * supplyvoltage / 1024;
// now print out the temperature
float temperatureC = (voltage - 0.5) * 100 ; //converting from 10 mv per degree wit 500 mV offset
//to degrees ((volatge - 500mV) times 100)
if (temperatureC!=maxi)
maxi=temperatureC;
Serial.print(reading); Serial.print(" reading, ");
Serial.print(supplyvoltage); Serial.print(" V power supply, ");
Serial.print(voltage); Serial.print(" volts, ");
Serial.print(temperatureC); Serial.println(" degrees C");
What is the value of "supplyVoltage"? And how do you have everything wired?
Post a photo and the complete code.
Supplyvoltage is calculated, look in the code.
Wiring is really dead-simple.
Just 3 wires, Gnd, 5v and A0 to their respective connector on the Tmp36.
The complete code:
The complete code:
An open-source LM35DZ Temperature Sensor for Arduino. This project will be enhanced on a regular basis
(cc) by Daniel Spillere Andrade , http://www.danielandrade.net
http://creativecommons.org/license/cc-gpl
int sensorPin = 0; // analog pin
int tempc = 0,tempf=0; // temperature variables
int samples[8]; // variables to make a better precision
int maxi = -100,mini = 100; // to start max/min temperature
#define BANDGAPREF 14 // special indicator that we want to measure the bandgap
void setup()
Serial.begin(9600); // start serial communication
void loop()
// print out the voltage
// Serial.println(refReading);
//Serial.print(temperatureF); Serial.println(" degress F");
Serial.print(supplyvoltage); //Serial.println("V power supply");
Serial.print(voltage); Serial.print(" volts ");
Serial.print(temperatureC); Serial.println(" degrees C");*/
maxi=temperatureC;
delay(1000); //waiting a second
So is the temperature. I guess they must both be correct then.Supplyvoltage is calculated, look in the code.
- zener
I would do this:
1) Add "refReading" to your print out info.
2) Measure your supply voltage with a volt meter
3) Measure the sensor voltage with a voltmeter (* edit, added this step *)
Then see if all the numbers are as they should be. Often times you need to take an anaolg read multiple times in succession to get a stable reading. Often the first one is bad, since the sampling cap has to charge.
Your biggest problem is you are using a TMP36 and using a program for the LM35.
The TMP35 is functionally the same as the LM35 - but you are using the TMP36.
LM35 - 250mv @ 25 degrees celcius
TMP36 - 750mv @ 25 degrees celcius.
Look at the data sheets :
http://www.analog.com/static/imported-f ... _36_37.pdf
You need to calculate the voltage for the sensor being used.
Here is the tutorial from LadyAda:
http://learn.adafruit.com/tmp36-temperature-sensor
If you are using standard 5v reference voltage try using this basic sketch.
it displays the temperature in degrees Fahrenheit.
/* Sketch written by JD3 2012
Uses TMP36 temperature senser from Adafruit
Pin 1 (left) +5v (or 3.3v)
Pin 2 (middle) Analog 0
Pin 3 (right) Ground
Adafruit Protoshield w/ TMP36 IC uses Analog pin 3
int volt = 0;
int Ftemp = 0; // use float for decimal, int for whole
Serial.begin(9600);
volt = analogRead(3);
Ftemp = (((volt * 4.8828125-500)/10)*9)/5 +32; // 5v reference
Serial.print(Ftemp);
Serial.println(" degrees");
delay(1000);
- zener
I don't think he is using the wrong formula. Look here: http://learn.adafruit.com/tmp36-temperature-sensor
He is using the correct formula for the TMP36, although he has modified it to use volts instead of millivolts.
void loop()
BANDGAPREF is set to 14, so refReading is a reading from analog pin 14?
What's connected to pin 14?
- zener
That part of the code self calibrates the AD converter, since the supply voltage is used as Vref HI but it is not known exactly what it might be. The internal band gap ref is known, so that is used to discover what the Vref HI is. That part of the code seems fine. If the OP tries what I suggested then we might get somewhere.JD3 wrote:What is refReading doing?
It is that portion of the code that is causing this problem.
I did not know about the band gap reference. So I looked up some info on that...
Thanks for explaining that Zener. Something new to play with
Several places checked show that analogRead() no longer supports the band gap function?
http://jeelabs.org/2012/05/04/measuring ... e-bandgap/
Also this post in Adafruit forums:
http://forums.adafruit.com/viewtopic.php?f=22&t=29946
Hi guys,
Sorry for the late reply but here it comes.
It was my fumbling that caused this sh#t
I took the sensor from the wrong bag... after reading the actual text on the bag, I realized it wasnt what I thought it was.
It was a MCP9701 giving the output 19,5mv / degree C... so now the readings correct... hmmm....sorry
Thanks again though for the rapid and creative responses!
/Karl
/Karl
- rowshay
I have found similar problems using the TMP36 temperature sensor on the Uno vs Mega. The readings being reported by the Mega 2560 were up to 4-7 degrees higher than what the exact same script (for the temperature reading/reporting portion) and jumpers/components were on the Uno. Where the Uno was reporting in the range of 25.20 to 26.66, the Mega was reporting 29.59 to 32.52.
The only difference between the two boards is that the Mega has the CC3000 WiFi shield on it, which is pushing the temperature value up to a web server on my network every 60 seconds (which stopped suddenly after 6 hours of posting, but that's another issue).
When I pulled the WiFi shield off and just connected everything to the Mega, and uploaded the same script, the numbers being reported between boards is only about 1-2 degree difference. (The TMP36 seems to jump around 1-3 degrees between readings of 30 seconds or less, but the average is fairly constant)
Note that I am using the 0.56" 7-segment LED HT16K33 backpack to display the results for on both boards.
So, it appears that the CC3000 shield introduces some variances in the analoge pin A0's voltage.
Check the voltages on the 5v pins of each Arduino.
The Arduino's ADC defaults to the 5v EXTERNAL voltage reference, which is taken from the 5v supply rail. That comes out of the 5v regulator, and the LT1117 series of regulators are only spec'd to be within 50mV of the nominal voltage. ADCs don't read voltage per se, they just measure fractions of the reference voltage, so there's a strong garbage-in/garbage-out factor.
To characterize the error, connect the Arduino's ADC to a voltage that remains stable, like an LED running from a wall-wart power supply. Collect a few thousand readings at whatever sampling rate you want to use, then graph them.
If you get nice, flat line, it means the error is just a DC offset. Calibrate the error by measuring the LED voltage with a multimeter, compare that to the millivolt equivalent of the ADC reading, and find the constant that makes the two equal. Then subtract that constant from your TMP36 readings before converting them to a temperature.
If the data samples move around rapidly, put a 10k resistor between the Arduino's 5v rail and its Aref pin, then drop a 10-100uF capacitor from the pin to GND. That will act as a filter to smooth out sudden changes in the reference voltage, which should make the readings more stable. Once the line is smooth enough for your purposes, figure the DC offset again.
