ultimate gps and pc serial port
by bilsch on Tue Jan 29, 2013 4:13 pm
Has anyone tried using the ultimate gps module on a standard pc serial port?
All I get from minicom is a bunch of jibberish
I have verified the serial config in minicom - 9600 8n1 no flow control
bilsch
Re: ultimate gps and pc serial port
by tastewar on Tue Jan 29, 2013 4:24 pm
I know all the doc says 9600 and that seems to be standard now for gps, but have you tried any other rates? 4800 was standard for gps for a long time; I've seen 19200...
tastewar
by bilsch on Tue Jan 29, 2013 4:54 pm
I did try other rates out of curiosity however i know for sure it is 9600
With the ftdi adapter 9600 8n1 works but I want to use the hardware serial port on a linux x86_64 box
Out of curiosity I tried another usb to serial adapter ( olllld adapter :-> ) I get the same thing - just a bunch of jibberish
bilsch
by bilsch on Tue Jan 29, 2013 5:10 pm
I'm not sure if using a multimeter will be accurate enough but thought it worth a shot.
So, when I hook the positive end of my multimeter to the tx out from the gps I see it get to around 3 volts. Is it possible the hardware serial adapter is giving me garbage because the signal voltage is too low?
http://en.wikipedia.org/wiki/RS-232#Voltage_levels
Valid signals are either in the range of +3 to +15 volts or the range -3 to -15 volts; the range between -3 to +3 volts is not a valid RS-232 level
bilsch
by tastewar on Tue Jan 29, 2013 5:35 pm
Sounds quite plausible. There's a link to a little board that would help in this thread:
http://forums.adafruit.com/viewtopic.php?f=10&t=32437
tastewar
by adafruit_support_bill on Tue Jan 29, 2013 5:57 pm
Yes a TTL to serial adapter is needed for interfacing with an RS232 serial port. The signal voltages on RS232 can cause damage to the GPS module.
by bilsch on Tue Jan 29, 2013 6:41 pm
What is the voltage of the gps module and what voltage is a pc serial port? Assuming the voltage off of rs232 serial port is higher than the gps module I suppose I could try to limit the voltage?
bilsch
by tastewar on Tue Jan 29, 2013 7:35 pm
But you have to boost the voltage in the other direction. There's a whole family of chips (e.g. MAX232) that bi-directionally convert between TTL level voltages and RS-232 levels. That little board I linked to (here it is again: http://www.suntekstore.com/goods-14002601-mini_rs232_to_ttl_converter_module_board_.html) has the support circuitry built-in, which is nice, but it's a crappy little thing otherwise. I went through 3 of them trying to solder wires to the little pads, and having the pads lift off the board :-/
Hence my asking if Adafruit would consider producing a similar product. Cause their stuff rocks.
tastewar
by bilsch on Tue Jan 29, 2013 7:50 pm
tastewar,
I completely missed your previous posting thanks I'll see if I can dig one of those up!
bilsch
by bilsch on Tue Jan 29, 2013 10:21 pm
tastewar,
That maxim chip would very likely resolve the rx/tx side of the equation ( my only stated need in this thread ;) ) but since this is for a gps unit I plan to also use pps as a part of the time sync for additional accuracy.
Oddly, with pps connected to the cts pin on the ftdi board I don't actually get the pulse registered in the kernel pps driver. I'm going to try out the gpio approach on my pi but my C foo is ... well, very very limited so far. i had posted on this previously and no one responded :-< ( viewtopic.php?f=19&t=36030&start=0&hilit=pi+gpio+pps )
Thanks for the hint about the maxim chip!
bilsch
by tastewar on Tue Jan 29, 2013 11:52 pm
I wonder if this tutorial, that I bookmarked earlier for myself, would help. It talks about using the GPIO serial port. Definitely avoids the need for level shifting!
http://learn.adafruit.com/adafruit-ultimate-gps-on-the-raspberry-pi/using-uart-instead-of-usb
tastewar
by bilsch on Wed Jan 30, 2013 2:37 pm
Yes, that does work though note they are not touching the pps side of the equasion.
Here are the links I'm looking over:
http://www.raspberrypi.org/phpBB3/viewt ... 8&p=129224
http://www.raspberrypi.org/phpBB3/viewt ... 06#p142606
It seems as though others have had the same idea re using the pi and gpio for the pps ( and hardware serial uart for comms ).
Curious this has not been merged in to the raspberry pi kernel yet. Guess if I can get it working I'll send a pull request.
bilsch
by ropesca on Wed Dec 25, 2013 9:55 pm
I have the same problem: I need to attach this GPS to a serial port on a PC to sync the clock, it means I need to use the PPS output. Wouldn't this converter work? http://www.adafruit.com/products/395
I just found RS232 to TTL with 4 pins (RX, TX, VCC, GND). How can I use the PPS pin with serial port (RS232)?
ropesca
by adafruit_support_mike on Thu Dec 26, 2013 3:14 am
Stepping back for a second, how will the PC recognize the pulse once you have the wiring right?
by ropesca on Thu Dec 26, 2013 5:22 am
I imagine it would work the same way that others GPS work: connecting PPS pulse to pin 1 RS232. No?
adafruit_support_mike wrote:Stepping back for a second, how will the PC recognize the pulse once you have the wiring right?
ropesca
cron
