How to set INA219 Current Sensor resolution lower?
by rbardsley on Wed Jan 30, 2013 9:37 pm
Hello, I am experimenting with the Adafruit INA219 Current Sensor Breakout Board.
I am trying to measure the current supplied to a standard LED. I have the INA219 wired properly and I am getting results that seem to be working properly. However, I want to increase my resolution. As it is an LED, and I am controlling the voltage and amperage, it's never going to be anywhere near the 32 AMP limit. So, in the product lit it says the board is capable of this:
With the internal gain set at the minimum of div8, the max current is ±400mA and the resolution is 0.1mA.
This sounds much better than the 0.8mA jumps I am getting now. However, when I looked at the library, it seems like I can get much better resolution... but I am not an electrical engineer or a mathematician. I don't have the faintest idea what I need to do to achieve the best resolution for measuring the current going to my LED.
Any suggestions?
Many thanks.
Ryan
Boston, MA
rbardsley
Re: How to set INA219 Current Sensor resolution lower?
by Electronicsconstructor45 on Wed Jan 30, 2013 10:23 pm
I believe the correct equation is divide-8 by the maximum Voltage then getting a reading or answer of 1.0Mili Amps correct me if im wrong im not that familiar with ampage as much
by Electronicsconstructor45 on Wed Jan 30, 2013 10:24 pm
i meant 0.1
by john444 on Wed Jan 30, 2013 10:32 pm
Hi Rbardsley,
All you should need to do is change the 'current-sense' resistor.
You might try replacing R5 (the one with R100) in the photo with
say, 1-ohm. Then instead of 3.2-A (max) & 0.8-mA resolution,
You would get 320-mA (max) & 0.08-mA resolution.
That should get you into the right ballpark for testing LEDs.
Good Luck, John
john444
by Electronicsconstructor45 on Wed Jan 30, 2013 10:34 pm
actully do what he said his idea works right mine doesnt seem close to his
by zener on Wed Jan 30, 2013 11:29 pm
I think technically you need to set bits 11 and 12 of the config register (PG0 and PG1) to set the gain you want. Complicated chip.
zener
