Looking to determine whether gas water heater is on
by Corwyn on Sun Feb 03, 2013 9:01 pm
I am working on a arduino based solar hot water system. One little side project is to determine whether the hot water I am getting is heated solely by solar, or whether the Bosch Aquastar tankless hot water heater has turned on to boost the temperature.
My first thought was to use a CdS light sensor, appropriately placed to see the light of the gas flame. The readings I am getting are too widely fluctuating to work based just on a threshold value.
Anyone have any ideas for a better way to determine whether the heater has kicked in?
Thank You Kindly,
Corwyn
Corwyn
Re: Looking to determine whether gas water heater is on
by Zener on Sun Feb 03, 2013 9:08 pm
PIR sensor. The kind they use in motion sensors. You will still get a fluctuating output but it should be usable. I never tried it though. You could also use a thermocouple I suppose. Or even a bimetallic temp switch "thermodisc".
Zener
by franklin97355 on Sun Feb 03, 2013 9:21 pm
Seems this is a great use of a thermocouple.
franklin97355
by Corwyn on Sun Feb 03, 2013 10:24 pm
Thanks, I may try that. I do worry that getting close enough to the flames to be able to differentiate hot water from flames will be closer than the thermocouple enjoys being.
Corwyn
by Zener on Sun Feb 03, 2013 11:02 pm
If it has a flue exhaust fan then you can sense that.
Zener
by adafruit_support_bill on Mon Feb 04, 2013 7:31 am
Or a even a flue exhaust damper should be detectable.
by Corwyn on Thu Mar 21, 2013 1:19 pm
It has neither. No electrical connection at all. Thank You Kindly.
Corwyn
by Zener on Thu Mar 21, 2013 4:31 pm
Did you try any of the other ideas?
There is also this from Home Depot
"Honeywell-Replacement-Thermopile-Generator-750-Millivolt-CQ200A"
I could not post the link because I got this message which I am not making up:
"Your message contains banned spam words. Please rephrase your post without the following words : xxxxx6986" where the xxxxx was 20318
Zener
by tastewar on Fri Mar 22, 2013 8:26 am
Sheesh, another guy trying to peddle that honeywell thermostat again! Will it never stop?! Guess we'll have to add "honeywell" or "thermostat" to the banned word list...
:wink:
tastewar
