Motor Driver connections.
Re: Motor Driver connections.
by MohitJindal on Tue Feb 05, 2013 10:48 am
Ok i will try that soon. Thanks. :D
MohitJindal
by MohitJindal on Thu Apr 25, 2013 11:54 pm
Hi; I have setup the connections and tried to run it. But the Red LED on the first photo IC.jpg is blinking. I think its due to overheating. :(
I connected PWM of motor driver board to the VCC. Is that PWM wire giving 5volt and some current to the VCC pin or VCC is giving some current to the PWM ? If I add 10k resistor in between PWM and VCC; will it stop the excess current and volts ? :?:
MohitJindal
