Diffused 5mm Slow Fade Flashing RGB LED on CR2032 Battery
by PipX on Thu Feb 07, 2013 2:34 pm
I'm doing a project with tabletop models where I want to illuminate some crystals with LEDs. If I'm using a CR2032 battery with 3V, 235 mAH, do I need to add a resistor in series with a single slow flashing LED?
PipX
Re: Diffused 5mm Slow Fade Flashing RGB LED on CR2032 Battery
by adafruit_support_bill on Thu Feb 07, 2013 3:01 pm
Not really. A resistor will give you a longer runtime, but it will work without one:
http://www.evilmadscientist.com/2009/so ... -throwies/
by PipX on Thu Feb 07, 2013 3:05 pm
Ah that's what I thought. I noticed though that on similar LEDs some of the colors (I think Red and White) show that they draw only around 1.6-1.8V, would using the 3V cell burn these out?
PipX
by zener on Thu Feb 07, 2013 4:24 pm
You are talking about the Vf of the LED which is how much voltage will be measured across it when it is on. Generally when you say something "draws" this or that we are talking about current not voltage. Nitpicker, nitpicker..
The Vf of an LED varies with color and the chemistry can have an affect also. Red are typically around 1.9 - 2, green 2.3 - 3 depending on type and blues 3v and up.
zener
