Closing Contacts with Raspberry Pi - novice question
by alfista on Thu Feb 14, 2013 11:29 pm
Hi All,
I'm a long-time IT guy, but I don't have much of a background in electrical engineering beyond simple wiring. I've picked up a Raspberry Pi to tinker with and I have a project/challenge I'm excited about trying to solve.
I found an obscure AMS Alpha 216 LED sign from 1991 (Like BetaBrite) at a yard sale and it works great. It has a wired alphanumeric keypad for programming that connects via a 14 pin ribbon cable but programming it is somewhat painful. Specs on the pinouts are basically nonexistent. I'd like to be able to configure it for remote, WiFi programming.
I was figuring I could use the GPIO board to simulate keystrokes to the display and I have RPi and WiringPi installed and working and I'm not too worried about the coding side of things. I've also used a multimeter to identify the pin combinations that represent the different keystrokes from the keyboard.
Thus my question: I understand how to make a pin an output pin and send current to ground to complete a circuit but I can't figure out how to close a circuit between two pins where one is not a ground, essentially simulating the keystroke on the keypad. I am not sure if I need additional hardware to achieve this task but I'm having fun learning: old dog new tricks.
Can someone point me to a resource that might help?
If I've posted in the wrong forum or used the wrong terms I apologize in advance.
Cheers!
alfista
Re: Closing Contacts with Raspberry Pi - novice question
by zener on Fri Feb 15, 2013 11:27 am
Most straightforward way is use relays. Here is an example that turns on the relay when your IO pin goes high:
http://playground.arduino.cc/uploads/Le ... relays.pdf
zener
