Plastic Valve 997 Duty Cycle
by hawk_08 on Wed Mar 13, 2013 11:14 am
Hello everyone,
I recently buy the 12V plastic valve (http://www.adafruit.com/products/997) and the information on the current was quite helpful, but I was wondering does anyone has any idea of the Duty cycle? I am building an automatic valve to fill up a tank. To set my limit I wanted to know how long can I leave the valve open withouth destroying it?
M.
hawk_08
Re: Plastic Valve 997 Duty Cycle
by adafruit_support_bill on Wed Mar 13, 2013 2:42 pm
I will check to see if there are more technical specs available. Typically with solenoid valves, the actuation current is quite a bit higher than the holding current. If you back-off on the holding current (via PWM), you can reduce coil heating considerably. Coil temperature is usually the limiting factor in duty-cycle ratings.
[Update]
We do not have a duty cycle spec on these. All the data we have from the manufacturer is posted on the product description page.
