Trying to install GpsDrive on Raspberry Pi
by John.R on Sun Mar 17, 2013 5:36 pm
Hello all,
I have been trying, unsuccessfully, to get the program GpsDrive http://www.gpsdrive.de/index.shtml on my RPi and I keep running into problems, the most recent of which is occurring when I try to run the cmake .. command to build it. The errors it returns are that it 'could NOT find GTK2' and 'could NOT find XML2' I am not really a prowrecker, er, programmer, so I am a bit lost as to solve this issue, if indeed it even can be. Any help would be greatly appreciated.
John.R
Re: Trying to install GpsDrive on Raspberry Pi
by adafruit_support_mike on Mon Mar 18, 2013 11:39 am
It looks like you're missing some library files the compiler needs. Try entering the following code:
sudo apt-get build-dep gpsdrive
