Hi, Bill
I tried to combine the ultrasonic code and the Flora backpack code. Unfortunately, the accelerometer sensor is not working properly. Any ideas how to fix this? Here is my code.
#include <Wire.h>
#include <Adafruit_LSM303.h>
#include "SPI.h"
#include "Adafruit_WS2801.h"
Adafruit_LSM303 lsm;
#define BRAKETHRESHOLD 350
#define BRAKETIMETHRESHOLD 200
int dataPin = 2; // Yellow wire on Adafruit Pixels
int clockPin = 3; // Green wire on Adafruit Pixels
const int cPin = 11;
const int dPin = 6;
// pin connected to analog output on maxsonar sensor
int sonarPin = A0;
// pin connected to digital output on red led
int ledPin = 7;
// Set the first variable to the NUMBER of pixels. 32 = 32 pixels in a row
// The LED strips are 32 LEDs per meter but you can extend/cut the strip
Adafruit_WS2801 strip = Adafruit_WS2801(36,dataPin,clockPin);
int start = 0;
int prevX = 0;
int currentX = 0;
int cState = 0;
int dState = 0;
long brakeTime = 0;
void setup()
Serial.begin(9600);
pinMode(ledPin, OUTPUT);
// Start up the LED strip
strip.begin();
// Update the strip, to start they are all 'off'
strip.show();
// Try to initialise and warn if we couldn't detect the chip
if (!lsm.begin())
Serial.println("Oops ... unable to initialize the LSM303. Check your wiring!");
while (1);
pinMode(cPin, INPUT);
pinMode(dPin, INPUT);
void loop()
// The Arduino’s analog-to-digital converter (ADC) has a range of 1024,
// which means each bit is ~4.9mV.
// Therefore, to convert the number returned by the ADC to inches, we
// have to divide by 2.
// To convert to cm is necessary to divide by 0.3937.
// 1 centimeter = 0.3937 inch
int distance = analogRead(sonarPin)/(4*0.3937);
Serial.print(distance, DEC); // prints the value read
Serial.println("cm");
// If something is at a distance less than 20 cm than LED lights up.
if(distance < 300) {
digitalWrite(ledPin, HIGH);
delay(5);
//digitalWrite(ledPin, LOW);
//delayMicroseconds(500);
else
delay(5);
check_switches(); // when we check the switches we'll get the current state
lsm.read();
currentX = abs(lsm.accelData.x);
if (start == 0){
prevX = currentX;
start = 1;
int i = currentX - prevX;
if (abs(i) > BRAKETHRESHOLD) {
brakeTime = millis();
int strikes = 0;
while ((abs(i) > BRAKETHRESHOLD) && (strikes < 3)) {
if (abs(i) < BRAKETHRESHOLD) {
strikes = strikes + 1;
lsm.read();
if ((millis() - brakeTime) > BRAKETIMETHRESHOLD) {
brakeLights(Color(255,0,0),250);
while (abs(i) > BRAKETHRESHOLD) {
lsm.read();
Serial.println(i);
delay(100);
hideAll();
i = 0;
lsm.read();
prevX = currentX;
delay(200);
void check_switches()
cState = digitalRead(cPin);
dState = digitalRead(dPin);
if (cState == HIGH) {
// left blinker
Serial.println("left blink on");
hideAll();
leftTurn(Color(255,63,0),250);
delay(300);
Serial.println("left blink off");
hideAll();
delay(300);
if (dState == HIGH) {
// right blinker
Serial.println("right blink on");
hideAll();
rightTurn(Color(255,63,0),250);
delay(300);
Serial.println("right blink off");
hideAll();
delay(300);
void leftTurn(uint32_t c,uint8_t wait){
innerLeftBottom(c);
innerLeftTop(c);
strip.show();
delay(wait);
hideAll();
outerLeftTop(c);
outerLeftBottom(c);
strip.show();
delay(wait);
hideAll();
void rightTurn(uint32_t c,uint8_t wait){
innerRightBottom(c);
innerRightTop(c);
strip.show();
delay(wait);
hideAll();
outerRightTop(c);
outerRightBottom(c);
strip.show();
delay(wait);
hideAll();
void brakeLights(uint32_t c, uint8_t wait){
innerRightTop(c);
innerLeftBottom(c);
innerLeftTop(c);
strip.show();
delay(wait);
hideAll();
outerLeftTop(c);
outerLeftBottom(c);
outerRightTop(c);
strip.show();
delay(wait);
hideAll();
/* Helper functions */
//Input a value 0 to 384 to get a color value.
//The colours are a transition r - g - b - back to r
void outerRightBottom(uint32_t c){
for (int i=0; i < 5; i++) {
strip.setPixelColor(i, c);
void outerRightTop(uint32_t c){
for (int i=5; i < 10; i++) {
void innerRightTop(uint32_t c){
for (int i=10; i < 14; i++) {
void innerRightBottom(uint32_t c){
for (int i=14; i < 18; i++) {
void innerLeftBottom(uint32_t c){
for (int i=18; i < 22; i++) {
strip.show();
void innerLeftTop(uint32_t c){
for (int i=22; i < 26; i++) {
void outerLeftTop(uint32_t c){
for (int i=26; i < 31; i++) {
void outerLeftBottom(uint32_t c){
for (int i=31; i < 36; i++) {
void hideAll(){
for(int i = 0; i < strip.numPixels();i++){
strip.setPixelColor(i,Color(0,0,0));
strip.show();
// Create a 24 bit color value from R,G,B
uint32_t Color(byte r, byte g, byte b)
uint32_t c;
c = r;
c <<= 8;
c |= g;
c <<= 8;
c |= b;
return c;
