There is no USPS pickup on Monday Feb 15th, 2016 because of President's Day. USPS orders placed after 11am EST Fri February 12th will go out Tuesday February 16. UPS orders will ship as normal.
9v solenoid: large or small?
by paulcj2 on Fri May 03, 2013 5:01 pm
I have two questions about your solenoids.
I'm creating a project to pull a string when a cat enters a door to cause the door to close behind her. The door is a standard screen door with a standard door closer. I want to prop the door open with a small stick, attach a string between it and one of your 9v solenoids. I'm building a circuit to activate the solenoid when the cat crosses a laser beam. I'm modifying the project shown here: http://www.youtube.com/watch?v=zQK1kTh57Fk to activate the solenoid instead of a camera, as shown in the video. I also want to activate an audio alarm, so I know when the door has been closed.
My first question is which of your 9v solenoids do you recommend:
The small one at: http://www.adafruit.com/products/412
Or the larger one at: http://www.adafruit.com/products/413 ?
My 2nd question is how do I need to modify the project in the video to work with your 9v solenoid?
paulcj2
Re: 9v solenoid: large or small?
by adafruit_support_bill on Sat May 04, 2013 5:37 am
A couple of problems there. First, the stroke on both of those solenoids is relatively short (small = 5.5mm. large = 10mm). That is not a long enough to close a door. Second, these are 24v solenoids. While they will work at 9v, the force at that voltage is very small.
For operating a door, you would be better off with a gearmotor or heavy-duty servo. Here's an example of a small door operated by a servo:
http://www.adafruit.com/blog/2012/12/11 ... -citizens/
by tastewar on Mon May 06, 2013 9:50 am
Don't believe the OP was looking to directly close the door. Door has a closer but is being propped open by a stick between door and jamb; attach string to stick; use solenoid to pull string to remove stick; closer will close door now that it's not propped open.
tastewar
by adafruit_support_bill on Mon May 06, 2013 10:02 am
That might work. But probably not at 9v. At that voltage, they do not have much force.
by paulcj2 on Wed May 08, 2013 1:06 pm
Thanks for the tip that this solenoid really works on 24 volts. Now the question is how best to provide that power. This is a small, short-term rig, so I really don't want to buy 2 12 volt car batteries and wire them in series. What low cost solution do you recommend?
By the way, a 9 volt battery didn't move the plunger at all.
paulcj2
by tastewar on Wed May 08, 2013 1:19 pm
Does it have to be battery? If not, I'd think that for a solenoid just about any 24vdc power supply/transformer would work. Product page claims 250ma required. eBay would be one possible source; here's another (didn't check shipping cost...) http://www.ispsupplies.com/categories/Power-Supplies/WiFi-Boxes-Low-Cost-24-Volt-DC-Power-Supply.html?gdftrk=gdfV25486_a_7c1893_a_7c7138_a_7cPS_d_24V_d_1A
tastewar
by adafruit_support_bill on Wed May 08, 2013 3:10 pm
A 9v battery has too much internal resistance to deliver that kind of current. The solenoid probably isn't even seeing 9v from the battery.
We do have 8xAA battery holders : http://www.adafruit.com/products/449
These will give you plenty of current at 12v with alkaline batteries.
A cheap transformer will do the job too - as suggested by tastewar.
by paulcj2 on Wed Jun 05, 2013 1:08 pm
Thanks for all the help. I ended up using the 24v DC converter/power supply. It worked very well with the solenoid pulling on one end of a stick holding the door open. I had to work on the door to get it to close and latch properly. Attached are pics of the final rig (overview, & control center), plus a pic of my cat Stella, safely at home.
Overview
Stella
Control Center
paulcj2
by adafruit_support_bill on Wed Jun 05, 2013 3:01 pm
Looks great! Thanks for posting.
And be sure to post Stella up on Cats of Engineering too! :D
http://www.adafruit.com/blog/2013/06/05 ... -update-3/
