This is an example for the Adafruit VS1053 Codec Breakout
Designed specifically to work with the Adafruit VS1053 Codec Breakout
----> https://www.adafruit.com/products/1381
products from Adafruit!
#include <SoftwareSerial.h>
// define the pins used
#define VS1053_RX 2 // This is the pin that connects to the RX pin on VS1053
#define VS1053_RESET 9 // This is the pin that connects to the RESET pin on VS1053
// Don't forget to connect the GPIO #0 to GROUND and GPIO #1 pin to 3.3V
// See http://www.vlsi.fi/fileadmin/datasheets/vs1053.pdf Pg 31
#define VS1053_BANK_DEFAULT 0x00
#define VS1053_BANK_DRUMS1 0x78
#define VS1053_BANK_DRUMS2 0x7F
#define VS1053_BANK_MELODY 0x79
// See http://www.vlsi.fi/fileadmin/datasheets/vs1053.pdf Pg 32 for more!
#define VS1053_GM1_OCARINA 80
#define MIDI_NOTE_ON 0x90
#define MIDI_NOTE_OFF 0x80
#define MIDI_CHAN_MSG 0xB0
#define MIDI_CHAN_BANK 0x00
#define MIDI_CHAN_VOLUME 0x07
#define MIDI_CHAN_PROGRAM 0xC0
SoftwareSerial VS1053_MIDI(0, 10); // TX only, do not use the 'rx' side
// on a Mega/Leonardo you may have to change the pin to one that
// software serial support uses OR use a hardware serial port!
Serial.begin(9600);
Serial.println("VS1053 MIDI test");
VS1053_MIDI.begin(31250); // MIDI uses a 'strange baud rate'
pinMode(VS1053_RESET, OUTPUT);
digitalWrite(VS1053_RESET, LOW);
delay(10);
digitalWrite(VS1053_RESET, HIGH);
delay(10);
midiSetChannelBank(0, VS1053_BANK_MELODY);
midiSetInstrument(0, VS1053_GM1_OCARINA);
midiSetChannelVolume(0, 127);
for (uint8_t i=60; i<69; i++) {
midiNoteOn(0, i, 127);
delay(100);
midiNoteOff(0, i, 127);
delay(1000);
void midiSetInstrument(uint8_t chan, uint8_t inst) {
if (chan > 15) return;
inst --; // page 32 has instruments starting with 1 not 0 :(
if (inst > 127) return;
VS1053_MIDI.write(MIDI_CHAN_PROGRAM | chan);
VS1053_MIDI.write(inst);
void midiSetChannelVolume(uint8_t chan, uint8_t vol) {
if (vol > 127) return;
VS1053_MIDI.write(MIDI_CHAN_MSG | chan);
VS1053_MIDI.write(MIDI_CHAN_VOLUME);
VS1053_MIDI.write(vol);
void midiSetChannelBank(uint8_t chan, uint8_t bank) {
if (bank > 127) return;
VS1053_MIDI.write((uint8_t)MIDI_CHAN_BANK);
VS1053_MIDI.write(bank);
void midiNoteOn(uint8_t chan, uint8_t n, uint8_t vel) {
if (n > 127) return;
if (vel > 127) return;
VS1053_MIDI.write(MIDI_NOTE_ON);
VS1053_MIDI.write(n);
VS1053_MIDI.write(vel);
void midiNoteOff(uint8_t chan, uint8_t n, uint8_t vel) {
VS1053_MIDI.write(MIDI_NOTE_OFF | chan);
