I am trying to increase my flying time of my RC helicopter by removing the 3.7 volt 1000mAH rechargeable battery, and replacing it with a 3.7 volt 2600 mAH battery.
It will not run the device. It acts like it's not getting a charge. The existing charger starts out showing a red LED, as if it is charging, but within a minute, it shows a green LED, as if it's fully charged, but isn't.
Could the charger be designed only for the 1000 mAH battery. what can I do to charge the 2600 mAH battery?
adding a larger mAH battery to my RC helicopter
- adafruit_support_mike
Re: adding a larger mAH battery to my RC helicopter
What battery chemistries are you using? There are several different kinds of rechargeable batteries these days, and each kind has to be charged in its own special way. NiCad chargers don't work for NiMH or LiPo batteries, NiMH chargers don't work for NiCad or LiPo, LiPo chargers don't work for NiCad or NiMH.
The original battery that was being charged from the charger was a LiPoly type, and the new larger battery is a LI Ion type. Will the same charger work on both types?
Just to confirm the battery types I looked up my adafruit order: the new battery is a lithium Ion polymer battery. 2600 mAH, 3.7 volts. the charger was originally charging a 1000 mAH 3.7 volt Li poly battery. Is this the same thing? the charger has an output of 3.7 volts 650 mAH. It also shuts down the charging process when the original 1000 mAH was fully charged. It wont do any charging to the 2600 mAH. The LED turns to green after one minute, thus indicating a full charge, yet there is only enough power to light up the helicopters' LED's , but will only for a microsecond, turn the blades before the chopper shuts down, as would happen when the normal battery became discharged. Thanks
There are a few variants of Lithium Ion Polymer chemistries with slightly different voltages and charging parameters.
What is the voltage output of your old battery when fully charged? And what voltage do you measure on the new battery? These cells have a nominal output of 3.7v. But like all batteries, the actual voltage varies a bit over as they discharge. They are fully charged at 4.2v and the internal protection circuit prevents them from being discharged to less than about 3v.
Just curious...
The adafruit chargers will charge a samsung 3.7 1300mAh Li/Ion battery I jacked from a busted phone, yeah?
I did read the product pages and it says yes for Li/Ion but says not for older ones 3.6/4.2v. Mine clearly says 4.7V, so should I be good? I just want top make sure before I order.
Thanx
S.
Thanx
S.
- Franklin97355
@Syn7 Should work just fine I have one charging a 4400 mah from Adafruit.
Sweet. Thanx for responding. Much appreciated.
S.
S.
