I have a chronodot, using RTCLib (from Adafruit GitHub repo), and time.h. I've already got a pretty decent NeoPixel Ring "analog" clock working with it all. Now...I want to add a calendar feature.
You know those whiteboard calendars with just a bunch of rows of seven boxes, and you get to fill in the dates for each new month? Well, I have a few 5x7 Bi-color LED matrix displays....and figured one could work in a similar way. I have the HT16K33 LED backpack working with it. I already made bmp's of all possible 'month-shapes' and can call/display them at will. I can already draw a single pixel of a different color to mark "Today" on the matrix. And, I can easily pull the day-of-week from RTCLib.
What I need (hope someone will help with) is using the RTC, RTClib, time library, and maybe some fun code to figure out the following —
• What day of week the current month begins with (Sunday, Mon, etc...)
• How many days in the current month
• The current week of the month (1st week, 2nd week....5th week?)
I need this in order to call the appropriate month bmp, and correctly place my "Today" pixel.
I've been digesting perpetual calendar formulas for the past day or so...and think there may be something there. I also think if I can maybe access some of the libraries' private variables, it may be easier....since it's already coming close to what I need.
Any help, code, formulae, links, etc....very appreciated.
Help w/ RTCLib, Chronodot, and a calendar.
Re: Help w/ RTCLib, Chronodot, and a calendar.
In case anyone is a bit more visual or has no idea what I'm talking about...here's a small demo.
I just 'cheated' and programmed in the next four months & have them rotating through the display. Which may be the best way to do the months...just have a look-up table or array? I'd rather do it with code....if it'll save any memory. I feel I'm gonna be pretty close to the limit by the time I'm done with everything. Either way, I still need to calculate which week it currently is.
http://youtube.com/watch?v=RBBwjlNioQg
It's a pretty quick little demo.
- jigsawnz
Here I have some code for you to check the days in a month. Wrote it for a project a year ago.
//void validateDay()
//Purpose: Check if it is a 30 day, 31 day, 28 day or 29 day month.
//Inputs: Integer, integer
//Outputs: Integer
int validateDay( int year, int month )
int day;
if ( month == 4 || month == 6 || month == 9 || month == 11 )
day = 30;
if ( month == 1 || month == 3 || month == 5 || month == 7 || month == 8||
month == 10 || month == 12)
day = 31;
if ( month == 2 )
day = daysInFebruary( year);
return day;
//void daysInFebruary()
//Purpose: Check if it is a leap year or not and check if the amount of days
// are within the range.
//Inputs:
//Outputs: Integer
int daysInFebruary( int year)
int maxDays;
if ( year % 4 == 0 )
if ( year % 100 == 0 )
if ( year % 400 == 0 )
maxDays = 29;
else
maxDays = 28;
else
maxDays = 29;
else
maxDays = 28;
return maxDays;
Sweet....thanks!
***SOLVED!***
Figured it out. I'll post my code in case anyone else ever needs something like this.
One by one:
This is actually in the time libraries already, so it knows when to start a new month.
Beginning with what day of the week today is, this can be calculated with functions from time.h library & my new favorite, "%".
From that we can find the last bit -
And to light up that day in my LED matrix....
The code could be made a bit simpler. But, I kept it like this to keep it very understandable.
Hope it helps someone!
Thanks again jigsawnz for posting a piece to the puzzle. It did help!
One by one:
int firstWeekdayOfMonth = weekday() - (day()%7) + 1;
// weekday() returns 1-7 for Sunday - Saturday
// day() returns today's date
// Example:
// Thursday, Sept 12, 2013
// weekday() returns '5'
// day() returns '12'
// 12 / 7 = 1 w/ remainder of 5
// 5 - 5 + 1 = 1 = Sunday was first weekday of the month
// Using same example date
int firstWeekEnds = 8 - firstWeekdayOfMonth;
// 8 - 1 = 7
// The 7th is Saturday, the last day of the first week in Sept 2013
// So...
int weekOne = firstWeekEnds;
int weekTwo = firstWeekEnds + 7; // 2nd week ends 7 days later
int weekThree = weekTwo + 7;
int weekFour = weekThree + 7;
int weekFive = weekFour + 7;
int weekSix = weekFive + 7;
// then compare to today's date
if (day() <= weekOne) thisWeek = 0
else if (day() <= weekTwo && day() > weekOne) thisWeek = 1;
else if (day() <= weekThree && day() > weekTwo) thisWeek = 2;
else if (day() <= weekFour && day() > weekThree) thisWeek = 3;
else if (day() <= weekFive && day() > weekFour) thisWeek = 4;
else if (day() <= weekSix && day() > weekFive) thisWeek = 5;
// Using 0 - 5 since that's what I need for my matrix y-coordinate.
int dayX = weekday() - 1; // since matrix starts with (0,0)
// and weekday() starts with '1'
int dayY = thisWeek; // from previous section of code
matrix.drawPixel(dayX, dayY, LED_RED); // Turns on red LED at correct point in matrix
matrix.writeDisplay();
