Voice Changer code Issue (Electronic Demon Costume)
Re: Voice Changer code Issue (Electronic Demon Costume)
by t0pd0g6969 on Mon Oct 21, 2013 1:45 pm
oh right, well the arduino board is connect via the DC power jack, but the wavesheild is directly from aref to 9v battery....
should i use a less voltage battery to power the waveshield?
t0pd0g6969
by adafruit_support_bill on Mon Oct 21, 2013 1:49 pm
You have the wave shield attached to the Arduino, so it is already being powered by the Arduino 5v pin.
by t0pd0g6969 on Mon Oct 21, 2013 2:00 pm
This is a quick diagram.
t0pd0g6969
by adafruit_support_bill on Mon Oct 21, 2013 2:10 pm
Remove the upper battery. If you are lucky, you have not already damaged the microphone amp and the Arduino's ADC.
Connect the red wire from the upper battery to the 3.3v pin. The black is already connected to GND.
You also indicate that you are powering the LEDs from the 9v battery. That is too high a voltage and you will damage the LEDs and backpacks that way. The tutorial uses a 3xAA (4.5V) battery pack to power these. http://learn.adafruit.com/animating-mul ... cks/wiring
by t0pd0g6969 on Mon Oct 21, 2013 2:11 pm
This diagram is probably more clear....(i think)....
t0pd0g6969
by adafruit_support_bill on Mon Oct 21, 2013 2:22 pm
That diagram shows two power sources for the LEDs - neither of which is appropriate.
As I mentioned earlier, the ONLY safe place to connect a 9v supply in this system is to the Arduino DC jack. Do not connect 9v to any other pin or any other component.
The 3.3v pin is also not sufficient to drive your LEDs. It is not capable of supplying enough current and you could damage the 3.3v regulator. You should get a 3xAA (4.5v) pack or some other poser source in the 4-5v range for your LEDs.
by t0pd0g6969 on Mon Oct 21, 2013 2:42 pm
Thanks alot.
Well i have just done wht you said and now i am getting the static noise. where should i connect the mic & 10k pot power connection?
t0pd0g6969
by adafruit_support_bill on Mon Oct 21, 2013 2:58 pm
Remove the red LED power wire entirely. Get a 4.5v supply for your leds and wire it as shown in the tutorial. http://learn.adafruit.com/animating-mul ... cks/wiring
Connect the red wire from the Mic and Pot to 3.3v.
Also connect a wire from 3.3v to AREF.
by t0pd0g6969 on Mon Oct 21, 2013 4:54 pm
Thanks bill, i got a clearer idea now and i hope my post will help other noobs who will attempt this project.
Thanks again. I will post a pic up soon as i get the additional stuff and finish.
t0pd0g6969
by t0pd0g6969 on Mon Oct 21, 2013 7:13 pm
Ok, if I understand...
I will connect like I have shown in the diagram. Is that right?
t0pd0g6969
by adafruit_support_bill on Mon Oct 21, 2013 7:42 pm
Yes. That looks right.
by t0pd0g6969 on Sun Oct 27, 2013 5:12 pm
Hi, I managed to finish the work on the demon project. Thank a lot for your help during the project. Really appreciate it.
I made a short video to show it working.
https://www.youtube.com/watch?v=1T-qF2b7ZUU
t0pd0g6969
