I have a project that uses the 128x32 I2C OLED display, 7-segment I2C LED, DS3231 RTC and and I2C accelerometer breakout board. The accelerometer breakout operates at 3.3 volts and has 10k I2C pullup resistors going to +3.3v. This is all running off an Arduino Pro-mini (5v version). The 3.3 volts comes from the voltage regulator on the OLED backpack.
Everything worked fine when the RTC, OLED and accelerometer were hooked up. Then I wired in the 7-segment display and the OLED stopped working. I suspected it had something to do with the I2C bus and the pullup resistors, so I added two 4.7k pullups to 3.3 volts. This is in addition to the 10k pullups to 3.3v on the accelerometer, so effectively these are in parallel (~7.4k). When I did this, everything worked. So my question is, how do I know what size pullups to use? Is there a rule of thumb based on number of devices on I2C bus?
Calculate I2C pull-up resistor size
Re: Calculate I2C pull-up resistor size
What you did is the real world way of determining the pull-up value.
There are very complex circuit simulation tools but in the end you try values.
The rule of thumb is about 2k to 10k for I2C pull-ups and the longer the I2C line (and/or more slave devices) the smaller the resistor value needed. I start with 4.7k pull-ups then adjust as needed.
FYI: a 10k in parallel with a 4.7k is not 7.4k its 3.2k.
Look up the parallel resistor equation and check your calculations.
- scott216
I'm not running at 100% yet today Thanks for the correction.waltr wrote:What you did is the real world way of determining the pull-up value.
- frank26080115
I usually find that 400KHz I2C busses will malfunction using 10K resistors at 3.3V, it's safer to start with 4.7K, and move down to 2.7K if you experience any errors.
