I have the PiMiner up and running, plus configured. But the PiMiner python script can't seem to find the MHS average on the first page. I can see the rest of the pages (on the 16x2 LCD) but when i go to the first page i only see ' MHS av" on both lines. Is there a setting i need to change in the python script for it to show this page?
Please let me know if you have any questions.
PiMiner and cgminer status API
Re: PiMiner and cgminer status API
Nope - it should work as-is. What version of cgminer are you running & what type of miner are you using?itorront wrote:Is there a setting i need to change in the python script for it to show this page?
Thanks for the reply!
I am running CGMiner 3.8.5 and i ahve a single (at the moment) Bitmain Antminer U1.
- mdax
I recompiled and now get the same result as the original poster first screen shows two lines of
'MHS av'
I'm very interested in what cgminer you are using
I can get my Ant U1 to 1.5Gh/s using https://github.com/AdvancedStyle/cgminer (3.8.5) however piminer hangs at "connecting to cgminer"
'MHS av'
- mdax
I managed to get my raspi working great with the LCD and Ant U1
Steps
git clone https://github.com/fractalbc/cgminer
cd cgminer
sudo apt-get install libusb-1.0
sudo apt-get install libudev-dev
./autogen.sh
./configure -–enable-bmsc
make -j 6
Running this .config
"pools" : [
"url" : "stratum.BANNED.cz:3333",
"user" : "minerName",
"pass" : "minerPassword"
"api-listen" : true,
"api-mcast-port" : "4028",
"api-port" : "4028",
"expiry" : "120",
"hotplug" : "5",
"failover-only" : true,
"log" : "5",
"no-pool-disable" : true,
"queue" : "1",
"scan-time" : "60",
"shares" : "0",
"kernel-path" : "/usr/local/bin",
"api-allow" : "0/0",
"bmsc-options" : "115200:20",
"bmsc-freq" : "0881"
Commands
sudo nohup /home/pi/cgminer/cgminer --config /home/pi/cgminer.frac.conf >/dev/null 2>&1&
sudo python /home/pi/cgminer/PiMiner/PiMiner.py &
Steps
cd cgminer
./autogen.sh
make -j 6
"pools" : [
"expiry" : "120",
"hotplug" : "5",
"log" : "5",
"queue" : "1",
"scan-time" : "60",
"shares" : "0",
Commands
Cool! Thanks for the Reply mdax.
I'll give it a try either tonight or this weekend. I'll post my results.
To resolve the 'MHS av' 'MHS av' problem edit the file PiMinerInfo.py ...
nano PiMinerInfo.py
Change line 143 which shows
s2 = 'avg:%s' % self.hashrate(float(d['MHS av']))
return [s1, s2]
to this
if ('MHS av' in d):
else:
s2 = 'avg GHs:%s' % float(d['GHS av'])
return [s1, s2]
nano PiMinerInfo.py
return [s1, s2]
to this
if ('MHS av' in d):
else:
return [s1, s2]
- jamesfreeman
I've made a slightly more elaborate fix, to keep everything properly decorated when the values scale:
Replace the "hashrate" subroutine with the following two subroutines:
Change the invocation within the parse_summary subroutine to:
Hope that this helps.
Jim
def hashrate_mega(self, h):
u = 'Mh/s'
if h >= 1000.0:
u = 'Gh/s'
h = h / 1000.0
elif h >= 1000000.0:
u = 'Th/s'
h = h / 1000000.0
s = '%s %s' % (h, u)
return s
def hashrate_giga(self, h):
u = 'Gh/s'
if h >= 1000.0:
u = 'Th/s'
h = h / 1000.0
return s
if 'MHS av' in d:
s2 = 'avg:%s' % self.hashrate_mega(float(d['MHS av']))
else:
s2 = 'avg:%s' % self.hashrate_giga(float(d['GHS av']))
Jim
