Is there a way to stop this? I don't really want the fish fed at every reboot of my chip or hiccup on the power line Is it a pullup or down resistor somewhere ? I don't want fat fish
Tim
motors run on repower with L293D and Atmeg328P ?
- timwjkl
- adafruit_support_bill
Re: motors run on repower with L293D and Atmeg328P ?
A pulldown on the Enable pins should help (pins 1 and 9). http://www.adafruit.com/datasheets/l293d.pdf
- timwjkl
10 K resistor from the enable pins to ground correct ? If that sounds good i will try that after work tonight.
Tim
Tim
That should do it.10 K resistor from the enable pins to ground correct ?
- timwjkl
Thanks that works great now when it boots no pumps or feeding. The 10 K resistor on pins 1 and 9 on the L293D is perfect.
Thank You
Tim
Thank You
Tim
The fish will be disappointed. No more free snacks
- timwjkl
Well this means I can cancel the personal trainers. The angles will be singing in the shallows and the corrys will be dancing in the weeds.
