On the "code" page there are 3 instructions at the top:
How do you insert the code into a file? Does the file exist or do you have to create it. If so, how do you do create and store the file?
Where do you get the audio files and how do you store it in the folder?
How do you make the file executable.
Herman
Playing sounds and using buttons with Raspberry Pi
Re: Playing sounds and using buttons with Raspberry Pi
Could you post a link to the page you're talking about please?
The instructions are saying to create a file named "raspi-audio-button.py", copy the code from the webpage into that file, then tell the OS to treat the file as a program it can run.
There are *many* different ways to create a file on a Linux machine. The `nano` text editor is fairly beginner-friendly and should let you create/edit/save the file:
will get things started.
Once you've copied the code to the file and saved it, use the command:
to make it runnable.
nano raspi-audio-button.py
chmod +x raspi-audio-button.py
