I play fighting games like Street Fighter or Marvel vs Capcom with a joystick that has a akishop PS360 PCB installed. Here is a link to the PCB:
http://www.BANNED.com/akishop-ps36 ... stick-pcb/
I would like to try to switch out the pushbuttons with the Momentary Capacitive Touch Sensor Breakout. From what it seems like, all I need to do is attach the GRD to a ground on the PCB, the OUT to the input I need, and VDD to either an external power source or the addition 3v VCC provided by the PS360 PCB.
Is that correct?
touch sensor buttons for an arcade stick
Re: touch sensor buttons for an arcade stick
The data sheet for the akishop board is not explicit about whether the buttons short to GND or V+. You should be able to tell by testing the connection terminals with a meter. If the buttons short to GND, the breakout should work.
- bricktop44
I'm doing something similar with the momentary cap touch sensor. For the PCB, im using the Xin-mo dual USB controller board. (http://www.xin-mo.com/?page_id=34)
When i connect OUT from the cap sensor to a button pin on the Xin-mo the button mapping/controller software indicated the arcade button is in a constant "pressed" state. When i touch the cap touch sensor the arcade button state is then off. Basically the reverse of what i need. Either i wired something backwards or i am missing a component in between something??? Cap sensor GND is connected to GND pin on the Xin-Mo, VDD getting power from the usb bus on the PC thats running the arcade emulation. Any thoughts or ideas? Im novice level at EE.
I don't know anything about the Xin-mo board. The momentary capacitive touch sensor sends the output high when you touch it. If the Xin-mo is expecting the inputs to be active low, then what you describe is to be expected. The 5-pad version is active-low, so that might be a better match for your xin-mo board.
https://www.adafruit.com/products/1362
