I am using Adafruit Thermal Printer.i need to interface this thermal printer with my Micro controller(Nuvoton-NUC121 series).
I have downloaded the code you have provided to interface with Arduino controllers which is also in c++.
how can i adapt or modify the code to interface with my controller .i will use UART -RS232 communication in my board.
Any help will appreciated,
Regards,
Sanath Rai
Adafruit Thermal Printer compatibility
Re: Adafruit Thermal Printer compatibility
I've moved this topic to General Project Help. Perhaps someone in the community has experience working with that microcontroller.
hi i'm also in-progress in learning nuvoton MCUs
they're nice since they are inexpensive, and powerful
well you can test the printer using PC serial port and a serial console (to test the commands in the manual pdf)
and then make the functions for each command, remember to convert ascii to binary first
well it's hard, but easier to do since we do it in a whole new environment
if you didn't know how to use the serial that's a whole other problem
