// Code for Adafruit GPS modules using MTK3329/MTK3339 driver
// This code shows how to listen to the GPS module in an interrupt
// which allows the program to have more 'freedom' - just parse
// when a new NMEA sentence is available! Then access data when
// desired.
// Tested and works great with the Adafruit Ultimate GPS module
// using MTK33x9 chipset
// ------> http://www.adafruit.com/products/746
// Pick one up today at the Adafruit electronics shop
// and help support open source hardware & software! -ada
// Also pick up an OLED Display at the Adafruit sore!
// ------> http://www.adafruit.com/products/661
// Sketch by Jeremy Saglimbeni - 07/14/12
// ------> http://thecustomgeek.com/2012/07/15/really-smalls-gps/
#define OLED_DC 4
#define OLED_CS 2
#define OLED_CLK 5
#define OLED_MOSI 6 // or "data" on the SSD1306
#define OLED_RESET 3
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
Adafruit_SSD1306 display(OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
#define LOGO16_GLCD_HEIGHT 16
#define LOGO16_GLCD_WIDTH 16
#include <Adafruit_GPS.h>
#include <SoftwareSerial.h>
SoftwareSerial mySerial(8, 9); // soft serial on pins 8 & 9
#define GPSECHO true
Adafruit_GPS GPS(&mySerial);
int mode = 0; // used to select what screen we draw
int left = A5; // left or top button
int mid = A3; // middle button
int right = A4; // right or bottom button
int power = 0; // power flag
int tzhour; // time zone adjusted hour
int tzday; // time zone adjusted day
int fixflag = 0; // if the GPS has a fix or not
int timezone = 5; // enter the time zone! (EST = 5);
int dst = 1; // Is it daylight savings time? 0 for no, 1 for yes.
float maxspeed;
float maxalt;
if (dst == 1) {
timezone--;
pinMode(13, OUTPUT); // LED for button presses
pinMode(A0, OUTPUT); // connected to the GPS "enabled" pin
digitalWrite(A0, HIGH); // pull it high! Low is sleep
pinMode(7, OUTPUT); // This is connected to the VIN of the OLED screen
digitalWrite(7, HIGH); // turn the screen on!
pinMode(left, INPUT);
pinMode(mid, INPUT);
pinMode(right, INPUT);
digitalWrite(left, HIGH);
digitalWrite(mid, HIGH);
digitalWrite(right, HIGH);
display.begin(SSD1306_SWITCHCAPVCC);
display.clearDisplay();
display.setTextSize(1);
display.setTextColor(WHITE);
display.setCursor(0,0);
display.println(" Where am I anyway?");
display.println(" ");
display.println(" Jeremy Saglimbeni");
display.print(" thecustomgeek.com");
display.display();
delay(1000);
GPS.begin(9600);
GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ); // 1 Hz update rate
delay(1000);
uint32_t timer = millis();
if (digitalRead(mid) == LOW) {
if (mode == 7) {
maxspeed = GPS.speed * 1.150779;
if (mode == 8) {
maxalt = GPS.altitude;
if (mode == 9) {
power++;
if (power == 2) {
power = 0;
if (power == 0) {
digitalWrite(13, HIGH);
display.setTextSize(2);
display.setCursor(0, 8);
display.print("I'm Awake!");
display.display();
delay(1500);
digitalWrite(13, LOW);
mode = 0;
if (power == 1) {
display.print("Goodnight!");
display.display();
delay(1500);
digitalWrite(A0, LOW);
digitalWrite(7, LOW);
delay(250);
if (digitalRead(left) == LOW) {
if (mode == 9) {
return;
mode++;
if (mode == 9) {
display.setCursor(0,8);
display.print("Sleep Mode");
display.display();
delay(1000);
return;
display.print(" Mode ");
display.print(mode);
display.display();
delay(500);
if (digitalRead(right) == LOW) {
if (power == 1) {
return;
if (mode == 0) {
return;
mode--;
display.display();
delay(500);
while (mySerial.available())
char c = GPS.read();
// if you want to debug, this is a good time to do it!
if ((c) && (GPSECHO))
Serial.write(c);
if (GPS.newNMEAreceived()) {
if (!GPS.parse(GPS.lastNMEA()))
return;
if (timer > millis()) timer = millis();
if ((GPS.speed * 1.150779) > maxspeed) {
if (GPS.altitude > maxalt) {
if (millis() - timer > 500) {
timer = millis(); // reset the timer
if (mode == 0) {
display.fillRect(0, 0, 127, 8, BLACK);
display.setCursor(0, 0);
if (GPS.hour >= 0 && GPS.hour < timezone) {
tzhour = GPS.hour + 20;
else {
tzhour = GPS.hour - timezone;
if (tzhour < 10) {
display.print("0");
display.print(tzhour, DEC);
display.print(':');
if (GPS.minute < 10) {
display.print("0");
display.print(GPS.minute, DEC);
display.print(':');
if (GPS.seconds < 10) {
display.print("0");
display.print(GPS.seconds, DEC);
display.print(" ");
if (GPS.month < 10) {
display.print("0");
display.print(GPS.month, DEC);
display.print("/");
if (tzhour >= 20) {
tzday = GPS.day - 1;
else {
tzday = GPS.day;
if (tzday < 10) {
display.print("0");
display.print(tzday, DEC);
display.print("/");
display.print("20");
display.print(GPS.year, DEC);
display.display();
if (GPS.fix == 0) {
display.fillRect(0, 16, 127, 16, BLACK);
display.setCursor(0, 16);
display.print("Acquiring Satellites!");
if (GPS.fix) {
fixflag = 1;
display.fillRect(0, 8, 128, 24, BLACK);
display.print("Lat:");
display.print(GPS.lat);
display.print(GPS.latitude, 4);
display.print("Lon:");
display.print(GPS.lon);
display.print(GPS.longitude, 4);
display.setCursor(0, 24);
display.print("Alt:");
display.print(GPS.altitude * 3.28084);
display.setCursor(92, 24);
if (GPS.fix == 1) {
display.print("Fix:");
display.print(GPS.satellites);
if (GPS.fix == 0) {
display.setTextColor(BLACK, WHITE);
display.print("NO FIX");
display.display();
if (mode == 1) {
if (GPS.fix) {
display.print("Speed(MPH):");
display.print(GPS.speed * 1.150779); //*converts to MPH
display.print("Bearing:");
display.print(GPS.angle);
display.setCursor(90, 24);
display.display();
if (mode == 3) {
display.setTextSize(4);
else {
if (tzhour < 10) {
display.print("0");
display.print(':');
display.print("0");
display.display();
if (mode == 2) {
else {
if (tzhour < 10) {
display.print("0");
display.print(':');
display.print("0");
display.print(":");
display.print("0");
display.print("0");
display.print("/");
if (tzhour >= 20) {
else {
tzday = GPS.day;
if (tzday < 10) {
display.print("0");
display.print("/");
display.display();
if (mode == 4) {
display.print(" MPH");
display.print(" DEG");
display.display();
if (mode == 9) {
display.print("Power Down");
display.print(" Really?");
display.display();
if (mode == 5) {
display.print("Ft");
display.display();
if (mode == 7) {
display.print("Max Speed");
display.print(maxspeed);
display.print("MPH");
display.display();
if (mode == 8) {
display.print("Max Alt-Ft");
display.print(maxalt);
display.display();
if (mode == 6) {
else {
if (tzhour < 10) {
display.print("0");
display.print(':');
display.print("0");
display.print(':');
display.print("0");
display.print(" ");
display.print("0");
display.print("/");
if (tzhour >= 20) {
else {
tzday = GPS.day;
if (tzday < 10) {
display.print("0");
display.print("/");
else {
display.display();
