Using libraries
Using libraries
Hi. I know that to some of the products here require the use of libraries. For example, NeoPixels. I started using the sample code that is included with the library; however, my question is: What is in the NeoPixel Library that can be used to program the NeoPixels? I can't find any reference to what is actually inside the library. I searched the reference guide for the NeoPixels too, but did not seem to find anything. Can anyone help? I would appreciate the guidance. Thanks.
- Franklin97355
Re: Using libraries
The library is the .h and .cpp files inside the library folder. Sometimes there is also a keywords file but beyond that reference materials are slim. Someday a bunch of Adafruit's friends (us) will decide to document them but don't hold your breath.
Re: Using libraries
Is there a reference guide on the commands that are available in the NeoPixel library? Or is there a way to program the pixels without the library?
Re: Using libraries
The NeoPixel Uberguide has all the general information about working with them: https://learn.adafruit.com/adafruit-neo ... e/overview
We don't have an explicit reference to the NeoPixel library because there are only about 10 functions in the library, and most of the critical code had to be written in ATmega assembler to get the timing right. The examples that come with the library show how to work with NeoPixels, and in practice a working example is as good a form of documentation as anything: https://github.com/adafruit/Adafruit_Ne ... r/examples
- Franklin97355
Re: Using libraries
These are the commands from the .cpp file
Adafruit_NeoPixel::Adafruit_NeoPixel(uint16_t n, uint8_t p, uint8_t t) : numLEDs(n), numBytes(n * 3), pin(p), pixels(NULL)
void Adafruit_NeoPixel::begin(void)
void Adafruit_NeoPixel::show(void)
void Adafruit_NeoPixel::setPin(uint8_t p)
void Adafruit_NeoPixel::setPixelColor(uint16_t n, uint8_t r, uint8_t g, uint8_t b)
void Adafruit_NeoPixel::setPixelColor(uint16_t n, uint32_t c)
uint32_t Adafruit_NeoPixel::Color(uint8_t r, uint8_t g, uint8_t b)
uint32_t Adafruit_NeoPixel::getPixelColor(uint16_t n)
uint8_t *Adafruit_NeoPixel::getPixels(void)
uint16_t Adafruit_NeoPixel::numPixels(void)
void Adafruit_NeoPixel::setBrightness(uint8_t b)
Re: Using libraries
I appreciate the information. You made my day today! :)
