Hello everyone!
I'm following this Forum for quick support on almost everything, so thanks in advance to everyone!
Getting to topic:
My project is running a main control unit for use in audio production and -mastering studios, a central hub as you wish. This project includes two of your 1.8" TFT displays (ST7735R), driven by two Arduino nano's. The question I have regards on the TFT-only kit, since i don't need an SD-Card interface at all.
As far as i could find out, the TFT-only kit includes the screen and the controller, leaving everything open on the fine-pitched flatwire. The logic level is 3.3V, so I'll have to add a logic-converter to not destroy the controller.
The question I have:
which logic-converter do you use on this TFT-shield as my first question, the second one is the pinout on the TFT itself. Because of the japanese datasheet i couldn't find out too much regarding this, so I'd appreciate some help/advice, if someone has some experience with this kit. Especially which line should be connected to what point, kind of important for the PCB-routing ;)
Information on the side: This product should be commercially available afterwards, so please tell me if there are some legal issues with my plan on using this kit.
Thanks in advance!
Khanorr
1.8" TFT help/information needed
- adafruit_support_rick
Re: 1.8" TFT help/information needed
Not really a kit - it's just a bare component. No licensing issues!
You can use 4050CD or 74LVX245 level shifter.
Thank you very much so far!
The only thing i need now is the needed Pins/lanes on the Display-Flex cable. Whilt carefully loosening the glue that holds the display in place i couldn't really see where which pin has to be connected with which pin on the board.
Are there any documents related to what need's to be connected where? The only thing I could find is the datasheet with foreign signs, i could'nt get thorugh it.
Thanks in advance!
Thanks in advance!
The datasheet is the only documentation we have.
You can refer to our schematic for clues:
https://github.com/adafruit/1.8-TFT-breakout
That's perfect, thank you very much!
Greetings,
Khanorr
Greetings,
Khanorr
