Recommedation for Sending Pressure Sensor Data
- lazerball
Have created a flexible cloth pressure sensor for paintball use. Need recommendation of arduino products to use to send 20 streams of information to computer. There will be 20 vests using these sensors all needing separate ids, all sending info simultaneously and vests are hit by reusable paintballs. Any help would be appreciated
Re: Recommedation for Sending Pressure Sensor Data
[moved to General Project help]
Will the vests have a wired connection to the Arduino or not?
- Franklin97355
Neat, what kind of signal does it output?Have created a flexible cloth pressure sensor for paintball use.
- lazerball
At this point in time yes, unless something simple is availableadafruit_support_mike wrote:[moved to General Project help]
For wired connections, you can use the MCP23008 and MCP23017 I2C port expanders:
https://www.adafruit.com/product/593 - MCP23008 (8 pins)
https://www.adafruit.com/products/732 - MCP23017 (16 pins)
They're both generic IO devices whose pins can be configured as inputs or outputs. They communicate with an Arduino or other microcontroller using I2C, so you only need two pins to talk to them. They also have address pins so you can put more than one of them on the same bus.. up to 8 of them, for a total of 64 GPIO lines with the '017.
