I'm attempting to use the 4 digit 7 segment Adafruit backpack to display data from Microsoft Flight simulator (string) using Link2FS and Arduino Mega.
Below is the Sketch which works with rotary encoders. I need the following string (hdgset) passed to the 7 seg:
void EQUALS(){
CodeIn = getChar(); // Get the second identifier
switch(CodeIn) {// Now lets find what to do with it
case 'd': // found AP heading setting
delay (11);
hdgset = "";
hdgset += getChar();
hdgsetold = hdgset;
}//end of case switch
}// end of void equals
I would REALLY appreciate your assistance as I'm in the final stages of this project but have been battling to get the 7 seg working 100%.
******** Whole sketch below ********
#include "Wire.h" // Enable this line if using Arduino Uno, Mega, etc.
#include "Adafruit_LEDBackpack.h"
#include "Adafruit_GFX.h"
Adafruit_7segment matrix = Adafruit_7segment();
This code is in the public domain
For use with "Link2fs_Multi"
Jimspage.co.nz
My thanks to the Guys that gave me snippets of code.
This is designed to be used with the Mega although it can be converted to use on the Uno.
This is just a "demo" of switching the sim's lights on and off and showing the
Autopilot target Altitude and the Vert.speed on a common 16x2 LCD.
It also shows the Heading and Flaps settings.
The LCD is connected to pins 2,3,4,5,6 and 7
The light switchs all use simconnect.(not "keys") but the remaining
pin's above pin 35 can be used for switchs using "Keys" in my program.
Some planes are not set up for individual switchings so just fiddle and
watch the extraction '<f' while clicking with your mouse or testing with
the "Test" button ,, most are OK tho.
On some planes it is even upside-down on some switchs.
It must have been a Monday morning job at M$ !!!
The 10 '1's or '0's being sent equate to,,,, (in order, left to right) ,,,
Nav, Beacon, Landing, Taxi, Strobe, Panel, Recognition, Wing, Logo, Cabin.
These lights codes suit the use of TOGGLE switchs as are in the planes for this purpose.
The other switchs are push button type. (Autopilot stuff, increase or decrease the
target Altitude and Vert speed.)
YOU NEED TO TICK THE FOLLOWING IN THE "Multi"
=b AP Autopilot Alt set
=c AP Autopilot Vert sp set
=d AP heading set
<G Flaps position
int CodeIn;// used on all serial reads
int KpinNo;
int Koutpin;
int hdg;
String KoldpinStateSTR, KpinStateSTR, Kstringnewstate,Kstringoldstate;
String altit, altitold, vertsp, vertspold, hdgset, hdgsetold, flaps, flapsold;
Kstringoldstate = "111111111111111111111111111111111111111111111111111111111111111111111";
for (int KoutPin = 22; KoutPin < 70; KoutPin++)// Get these pins ready as inputs
pinMode(KoutPin, INPUT);
digitalWrite(KoutPin, HIGH);
#ifndef __AVR_ATtiny85__
Serial.println("7 Segment Backpack Test");
#endif
matrix.begin(0x70);
Serial.begin(115200);
{INPUTS();} //Check the "Inputs" section
if (Serial.available()) {
CodeIn = getChar();
if (CodeIn == '=') {EQUALS();} // The first identifier is "="
if (CodeIn == '<') {LESSTHAN();}// The first identifier is "<"
if (CodeIn == '?') {QUESTION();}// The first identifier is "?"
if (CodeIn == '/') {SLASH();}// The first identifier is "/" (Annunciators)
}//end of serial read bit
}//end of void loop
char getChar()// Get a character from the serial buffer
while(Serial.available() == 0);// wait for data
return((char)Serial.read());// Thanks Doug
void EQUALS(){
delay (11);
hdgset = "";
hdgsetold = hdgset;
void LESSTHAN(){ // The first identifier was "<"
CodeIn = getChar(); // Get another character
case 'A'://Found the second identifier
//Do something
break;
case 'B':
//Do something
break;
case 'f':
// Do something
case 'G'://Found the second identifier ("G" Flaps position)
// Do something
break;
}//end of case method
}//end of lessthan
void QUESTION(){ // The first identifier was "?"
//do something
}// end of question
void SLASH(){ // The first identifier was "/" (Annunciator)
//Do something
void INPUTS()
Kstringnewstate = "";
for (int KpinNo = 22; KpinNo < 70; KpinNo++){// Pins 22 thru to 69 are all inputs
KpinStateSTR = String(digitalRead(KpinNo));
KoldpinStateSTR = String(Kstringoldstate.charAt(KpinNo - 22));//the 22 needs to be the same as the 22 in the "for" loop line.
if (KpinStateSTR != KoldpinStateSTR)
if (KpinNo == 22){if (KpinStateSTR == "1" ){Serial.println ("C410");}else {Serial.println ("C411");}}//Nav lights
if (KpinNo == 23){if (KpinStateSTR == "1" ){Serial.println ("C420");}else {Serial.println ("C421");}}//Beacon lights
if (KpinNo == 24){if (KpinStateSTR == "1" ){Serial.println ("C430");}else {Serial.println ("C431");}}//Landing lights
if (KpinNo == 25){if (KpinStateSTR == "1" ){Serial.println ("C440");}else {Serial.println ("C441");}}//Taxi lights
if (KpinNo == 26){if (KpinStateSTR == "1" ){Serial.println ("C450");}else {Serial.println ("C451");}}//Strobe lights
if (KpinNo == 27){if (KpinStateSTR == "1" ){Serial.println ("C460");}else {Serial.println ("C461");}}//Panel lights
if (KpinNo == 28){if (KpinStateSTR == "1" ){Serial.println ("C470");}else {Serial.println ("C471");}}//Recognitian lights
if (KpinNo == 29){if (KpinStateSTR == "1" ){Serial.println ("C480");}else {Serial.println ("C481");}}//Wing lights
if (KpinNo == 30){if (KpinStateSTR == "1" ){Serial.println ("C490");}else {Serial.println ("C491");}}//Logo lights
if (KpinNo == 31){if (KpinStateSTR == "1" ){Serial.println ("C500");}else {Serial.println ("C501");}}//Cabin lights
if (KpinNo == 32 & KpinStateSTR == "1" ){Serial.println ("B11");}//Autopilot altitude set
if (KpinNo == 33 & KpinStateSTR == "1" ){Serial.println ("B12");}//Autopilot altitude set
if (KpinNo == 34 & KpinStateSTR == "1" ){Serial.println ("B13");}//Autopilot vert speed set
if (KpinNo == 35 & KpinStateSTR == "1" ){Serial.println ("B14");}//Autopilot vert speed set
// add more direct inputs here but raise the pinNo (35) in the above live and the line below.
//now the "keys" bit. Note the pinNo 35 in the line above and the line below.
if (KpinNo > 35){
Serial.print ("D");
if (KpinNo < 10) Serial.print ("0");
Serial.print (KpinNo);
Serial.println (KpinStateSTR);
}//end of "keys" bit
}//end of yes it's different
Kstringnewstate += KpinStateSTR;
}//end of "for" loop
Kstringoldstate = Kstringnewstate;
}//end of OUTPUTS void
